Hello,
I am trying to work on comparing a block of data from an RFID card.
So far all I have it doing is printing a set text when an RFID card is picked up.
I keep getting this error when trying to compare code: "NFC_working_sketch:132: error: invalid use of void expression"
@file nfc_mifare_mf1s50_reader.ino
@author www.elechouse.com
@brief example of reading mf1s50 card for NFC_MODULE
For this demo, waiting for a MF1S50 card or tag, after reading a card/tag UID,
then try to read the block 4/5/6/7 ..
@section HISTORY
V1.0 initial version
Copyright (c) 2012 www.elechouse.com All right reserved.
/** include library */
#include "nfc.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
/** define a nfc class */
NFC_Module nfc;
void setup(void)
lcd.begin(16, 2);
nfc.begin();
Serial.println("MF1S50 Reader Demo From Elechouse!");
uint32_t versiondata = nfc.get_version();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
/** Set normal mode, and disable SAM */
nfc.SAMConfiguration();
void loop(void)
u8 buf[32],sta;
/** Polling the mifar card, buf[0] is the length of the UID */
sta = nfc.InListPassiveTarget(buf);
lcd.setCursor(0,0);
lcd.print("Waiting for card...");
/** check state and UID length */
if(sta && buf[0] == 4){
/** the card may be Mifare Classic card, try to read the block */
Serial.print("UUID length:");
Serial.print(buf[0], DEC);
Serial.print("UUID:");
nfc.puthex(buf+1, buf[0]);
/** factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF */
u8 key[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
u8 blocknum = 4;
/** Authentication blok 4 */
sta = nfc.MifareAuthentication(0, blocknum, buf+1, buf[0], key);
if(sta){
/** save read block data */
u8 block[16];
Serial.println("Authentication success.");
lcd.setCursor(0,1); // First line
lcd.print("Lewis NFC");
// uncomment following lines for writing data to blok 4
strcpy((char*)block, "Elechoues - NFC");
sta = nfc.MifareWriteBlock(blocknum, block);
if(sta){
Serial.println("Write block successfully:");
/** read block 4 */
sta = nfc.MifareReadBlock(blocknum, block);
if(sta){
Serial.println("Read block successfully:");
nfc.puthex(block, 16);
/** read block 5 */
sta = nfc.MifareReadBlock(blocknum+1, block);
if(sta){
/** read block 6 */
sta = nfc.MifareReadBlock(blocknum+2, block);
if(sta){
/** read block 7 */
sta = nfc.MifareReadBlock(blocknum+3, block);
if(sta){
char buffer[] = "BL BL BL BL BL BL BL";
int r;
r=memcmp ( buffer , nfc.puthex(block, 16), 16);
if(r > 0){
char print='This is bigger';
char print='This is not bigger';
lcd.clear();
PLEASE NOTE: I have googled this problem because I was initially trying to set the variable as a char. Then I switched to including it directly as part of the memcmp() function. I don't know where to start in repairing the issue so any advice is gratefully received.
