so followed all the steps on E3Ds site and i get this error
Arduino: 1.8.13 (Windows 10), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
Sketch uses 125530 bytes (96%) of program storage space. Maximum is 130048 bytes.
Global variables use 6297 bytes (38%) of dynamic memory, leaving 10087 bytes for local variables. Maximum is 16384 bytes.
avrdude: Expected signature for ATmega1284P is 1E 97 05
Double check chip, or use -F to override this check.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
option enabled in File -> Preferences.
Please post a link to the instructions you're following so we can understand what you're doing. Many of the people here on the forum (including myself) are very knowledgeable about Arduino, but not at all about 3D printers.
this, although the links they had didnt work anymore so i had to go find new ones for the Sanguino and for the marlin files
From now on you should be able to connect the Ender 3 to the computer via the mini USB cable.
Once you finish burning the bootloader on the Ender 3 using the Uno, you need to disconnect the Uno from the Ender 3 and then connect the Ender 3 directly to your computer with the USB cable.
The reason you're getting this error is because you're trying to upload Marlin to the Uno you were using as an "Arduino as ISP" programmer to burn the bootloader instead of uploading it to the 3D printer control board.
pert:
OK, I think you skipped this part of Step 11:Once you finish burning the bootloader on the Ender 3 using the Uno, you need to disconnect the Uno from the Ender 3 and then connect the Ender 3 directly to your computer with the USB cable.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\irish\AppData\Local\Temp\arduino_build_258346/Marlin.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM4"
avrdude done. Thank you.
An error occurred while uploading the sketch
The reason for this error is you still have the port from the Uno selected. The 3D printer control board has a different COM port. You need to select that port from the Arduino IDE's Tools > Port menu before uploading.
If you don’t know which port is your 3d printer board, you can find it like this:
Unplug your 3D printer's USB cable from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Plug your 3D printer's USB cable back into the computer.
Tools > Port - The new port listed in the menu is your 3D printer board.
pert:
Tools > Port
so i unplugged it, no ports listed, closed the tools menu, plugged it back in, said com4, hit upload and
Using Port : COM4
pert:
Hmmm. Try restarting your computer. Sometimes the port can get stuck in a state where it can't be used and the restart recovers it.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\irish\AppData\Local\Temp\arduino_build_773282/Marlin.ino.hex:i
Using Port : COM4
still nothing
also doesnt work when i try a new port
Connect the Uno to your computer with a USB cable.
(In the Arduino IDE) Tools > Port > select the port of the Uno.
(In the Arduino IDE) Sketch > Upload Using Programmer
Wait for the upload to finish successfully.
Unplug the Uno's USB cable from your computer.
Disconnect the Uno from the 3D printer.
After that, your 3D printer firmware will be updated and you can use it as usual.
The only downside to this workaround is you will always need to reconnect the Uno to your 3D printer every time you want to update the 3D printer firmware. But that's not so bad. If you do it a lot, you can buy a 6 pin USBasp programmer from eBay to use instead of the Uno. The USBasp programmer has a cable that plugs right in to your 3D printer board so you don't need to deal with getting all the jumper wires between the Uno and the printer board just right every time. But the Uno used as an "Arduino as ISP" programmer works great and as a bonus you have a nice Uno to play around with when you're not using it as a programmer.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -cstk500v2 -Pusb -Uflash:w:C:\Users\irish\AppData\Local\Temp\arduino_build_732719/Marlin.ino.hex:i
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb" (0x03eb:0x2104)
This error is caused by having the wrong programmer selected from the Arduino IDE's Tools > Programmer menu. I omitted that from my previous instructions because I assumed you already had it configured from when you burned the bootloader the last time you followed the https://e3d-online.zendesk.com/hc/en-us/articles/360017637858-Hemera-Ender-3-Firmware tutorial.
Please select Tools > Programmer > Arduino as ISP in the Arduino IDE and then follow the instructions in my previous reply again.
You're welcome. I'm glad to hear it's working now.
That "ArduinoISP" vs "Arduino as ISP" thing is super confusing, especially considering the sketch used to turn your Uno into an "Arduino as ISP" is named "ArduinoISP".
pert:
Enjoy your updated 3D printer!
Per
thanks, this is only temporary until my new board that is better gets here lol then i get to enjoy getting that to work, have a great day.
