Trying to configure cotestatnt/esp-fs-webserver with username password
Hi Everybody,
I have quite some experience with "standard"-programming but no experiences with the deeper specialties of C++-coding.
I'm trying to configure the esp-fs-webserver from user cotestatnt to work with username and password. This is the GiPo with the library
I looked into the headerfile
https://github.com/cotestatnt/esp-fs-webserver/blob/main/src/esp-fs-webserver.h
and the cpp-file
https://github.com/cotestatnt/esp-fs-webserver/blob/main/src/esp-fs-webserver.cpp
But I have only a dark intuition what I might have to change to get access to the website only after entering a username and a password
In the cpp-file
there are line 72 and 73
// OTA update via webbrowser
    m_httpUpdater.setup(webserver);
which calls a setup-function
So I tried to followback where this comes from but are totally unsire if I'm on the right track
the header-file
has line 28
    using UpdateServerClass = ESP8266HTTPUpdateServer;
#elif defined(ESP32)
which mentions ESP8266HTTPUpdateServer
So I tried to find this ESP8266HTTPUpdateServer
and found it on my harddisk
here
C:\Users\dipl-\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266HTTPUpdateServer\src\ESP8266HTTPUpdateServer.h
#ifndef __HTTP_UPDATE_SERVER_H
#define __HTTP_UPDATE_SERVER_H
#include <ESP8266WebServer.h>
namespace esp8266httpupdateserver {
using namespace esp8266webserver;
template <typename ServerType>
class ESP8266HTTPUpdateServerTemplate
  public:
    ESP8266HTTPUpdateServerTemplate(bool serial_debug=false);
    void setup(ESP8266WebServerTemplate<ServerType> *server)
      setup(server, emptyString, emptyString);
    void setup(ESP8266WebServerTemplate<ServerType> *server, const String& path)
      setup(server, path, emptyString, emptyString);
    void setup(ESP8266WebServerTemplate<ServerType> *server, const String& username, const String& password)
      setup(server, "/update", username, password);
    void setup(ESP8266WebServerTemplate<ServerType> *server, const String& path, const String& username, const String& password);
    void updateCredentials(const String& username, const String& password)
      _username = username;
      _password = password;
  protected:
    void _setUpdaterError();
  private:
    bool _serial_output;
    ESP8266WebServerTemplate<ServerType> *_server;
    String _username;
    String _password;
    bool _authenticated;
    String _updaterError;
#include "ESP8266HTTPUpdateServer-impl.h"
using ESP8266HTTPUpdateServer = esp8266httpupdateserver::ESP8266HTTPUpdateServerTemplate<WiFiServer>;
namespace BearSSL {
using ESP8266HTTPUpdateServerSecure = esp8266httpupdateserver::ESP8266HTTPUpdateServerTemplate<WiFiServerSecure>;
#endif
This header-file has a function setup that has parameters username and password
So my assuming is there is a possability to configure it to use username and password.
I have no idea what a syntax like
File root = m_filesystem->open("/", "r");
especially the "->"
How would I build a version of the cotestatnt/esp-fs-webserver that has a locked door in front of all subsites
enter username and password
to get access to it?
best regards Stefan
