Trying to control 13 Servos with Potentiometers.
I found someones code and circuit for controlling a servo with one pot and tried to figure out how to duplicate it on my own. I have already heard that potentiometers are not the best way of controlling servos so if you have another way feel free to tell me but I still need help with the supplies that I have. I know how to set up the physical circuit so I just need help to make sure the code is written correctly. I would just try it but the last time I just tried code my board died and I'm not rich.
// Controlling 13 servos position using potentiometers
#include <Servo.h>
Servo servo0; // create servo object to control a servo
Servo servo1; // create servo object to control a servo
Servo servo2; // create servo object to control a servo
Servo servo3; // create servo object to control a servo
Servo servo4; // create servo object to control a servo
Servo servo5; // create servo object to control a servo
Servo servo6; // create servo object to control a servo
Servo servo7; // create servo object to control a servo
Servo servo8; // create servo object to control a servo
Servo servo9; // create servo object to control a servo
Servo servo10; // create servo object to control a servo
Servo servo11; // create servo object to control a servo
Servo servo12; // create servo object to control a servo
int val0; // variable to read the value from the analog pin
int val1; // variable to read the value from the analog pin
int val2; // variable to read the value from the analog pin
int val3; // variable to read the value from the analog pin
int val4; // variable to read the value from the analog pin
int val5; // variable to read the value from the analog pin
int val6; // variable to read the value from the analog pin
int val7; // variable to read the value from the analog pin
int val8; // variable to read the value from the analog pin
int val9; // variable to read the value from the analog pin
int val10; // variable to read the value from the analog pin
int val11; // variable to read the value from the analog pin
int val12; // variable to read the value from the analog pin
int potpin0 = 0; // analog pin used to connect the potentiometer
int potpin1 = 1; // analog pin used to connect the potentiometer
int potpin2 = 2; // analog pin used to connect the potentiometer
int potpin3 = 3; // analog pin used to connect the potentiometer
int potpin4 = 4; // analog pin used to connect the potentiometer
int potpin5 = 5; // analog pin used to connect the potentiometer
int potpin6 = 6; // analog pin used to connect the potentiometer
int potpin7 = 7; // analog pin used to connect the potentiometer
int potpin8 = 8; // analog pin used to connect the potentiometer
int potpin9 = 9; // analog pin used to connect the potentiometer
int potpin10 = 10; // analog pin used to connect the potentiometer
int potpin11 = 11; // analog pin used to connect the potentiometer
int potpin12 = 12; // analog pin used to connect the potentiometer
servo0.attach(0); // attaches the servo on pin 0 to the servo object
servo1.attach(1); // attaches the servo on pin 1 to the servo object
servo2.attach(2); // attaches the servo on pin 2 to the servo object
servo3.attach(3); // attaches the servo on pin 3 to the servo object
servo4.attach(4); // attaches the servo on pin 4 to the servo object
servo5.attach(5); // attaches the servo on pin 5 to the servo object
servo6.attach(6); // attaches the servo on pin 6 to the servo object
servo7.attach(7); // attaches the servo on pin 7 to the servo object
servo8.attach(8); // attaches the servo on pin 8 to the servo object
servo9.attach(9); // attaches the servo on pin 9 to the servo object
servo10.attach(10); // attaches the servo on pin 10 to the servo object
servo11.attach(11); // attaches the servo on pin 10 to the servo object
servo12.attach(12); // attaches the servo on pin 10 to the servo object
val0 = analogRead(potpin0); // reads the value of the potentiometer (value between 0 and 1023)
val1 = analogRead(potpin1); // reads the value of the potentiometer (value between 0 and 1023)
val2 = analogRead(potpin2); // reads the value of the potentiometer (value between 0 and 1023)
val3 = analogRead(potpin3); // reads the value of the potentiometer (value between 0 and 1023)
val4 = analogRead(potpin4); // reads the value of the potentiometer (value between 0 and 1023)
val5 = analogRead(potpin5); // reads the value of the potentiometer (value between 0 and 1023)
val6 = analogRead(potpin6); // reads the value of the potentiometer (value between 0 and 1023)
val7 = analogRead(potpin7); // reads the value of the potentiometer (value between 0 and 1023)
val8 = analogRead(potpin8); // reads the value of the potentiometer (value between 0 and 1023)
val9 = analogRead(potpin9); // reads the value of the potentiometer (value between 0 and 1023)
val10 = analogRead(potpin10); // reads the value of the potentiometer (value between 0 and 1023)
val11 = analogRead(potpin11); // reads the value of the potentiometer (value between 0 and 1023)
val12 = analogRead(potpin12); // reads the value of the potentiometer (value between 0 and 1023)
val0 = map(val0, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val1 = map(val1, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val2 = map(val2, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val3 = map(val3, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val4 = map(val4, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val5 = map(val5, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val6 = map(val6, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val7 = map(val7, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val8 = map(val8, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val9 = map(val9, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val10 = map(val10, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val11 = map(val11, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
val12 = map(val12, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
servo0.write(val0); // sets the 0 servo position according to the scaled value
servo1.write(val1); // sets the 1 servo position according to the scaled value
servo2.write(val2); // sets the 2 servo position according to the scaled value
servo3.write(val3); // sets the 3 servo position according to the scaled value
servo4.write(val4); // sets the 4 servo position according to the scaled value
servo5.write(val5); // sets the 5 servo position according to the scaled value
servo6.write(val6); // sets the 6 servo position according to the scaled value
servo7.write(val7); // sets the 7 servo position according to the scaled value
servo8.write(val8); // sets the 8 servo position according to the scaled value
servo9.write(val9); // sets the 9 servo position according to the scaled value
servo10.write(val10); // sets the 10 servo position according to the scaled value
servo11.write(val11); // sets the 11 servo position according to the scaled value
servo12.write(val12); // sets the 10 servo position according to the scaled value
delay(15); // waits for the servos to get there
srry about the face idk how to make that go away
ExoWarlock9031:
Read the stickies at the top of the forum - the ones you were supposed to read BEFORE you blundered in here. Learn to post code correctly.
It is not. Instead of all those scalar variables, some arrays would cut the code by 75%.
How are you powering the servos?
with 4 AA batteries each
Which Arduino has so many analog input pins?
Paul
Would have to be a Mega to have so many analog inputs and servo control ports.
Yes its a mega board
Also i know arrays would shorten the code but i dont know how to do that so I just wanted to know if this would function and not destroy my board
Now would seem to be a very good time to learn.
You can rest assured that the code won't destroy your board. No such guarantee can be made regarding anything you connect to the Arduino, since you have provided no schematic.
