Hi all, I am just playing around with the Web_AjaxRGB_mobile sketch in the examples and trying to control 2 LED's
I have duplicated the bits I thought I needed to and added variables for a second LED. It compiles and looks OK on a browser (two sets of silders show up) but I can see through the serial monitor that the values for reda, greena, bluea, redb, greenb and blueb don't update. I'm really stuck now, what have I missed?
Thanks
/* Web_AjaxRGB_mobile.pde - example sketch for Webduino library */
/* - offers web-based slider controllers for RGB led - */
#include "SPI.h"
#include "Ethernet.h"
#include "WebServer.h"
// CHANGE THIS TO YOUR OWN UNIQUE VALUE
static uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// CHANGE THIS TO MATCH YOUR HOST NETWORK
static uint8_t ip[4] = { 192, 168, 0, 177 }; // area 51!
/* all URLs on this server will start with /rgb because of how we
* define the PREFIX value. We also will listen on port 80, the
* standard HTTP service port */
#define PREFIX "/rgb"
WebServer webserver(PREFIX, 80);
#define REDA_PIN 2
#define GREENA_PIN 3
#define BLUEA_PIN 4
#define REDB_PIN 5
#define GREENB_PIN 6
#define BLUEB_PIN 7
int reda = 0; //integer for red darkness
int bluea = 0; //integer for blue darkness
int greena = 0; //integer for green darkness
int redb = 0; //integer for red darkness
int blueb = 0; //integer for blue darkness
int greenb = 0; //integer for green darkness
/* This command is set as the default command for the server. It
* handles both GET and POST requests. For a GET, it returns a simple
* page with some buttons. For a POST, it saves the value posted to
* the red/green/blue variable, affecting the output of the speaker */
void rgbCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
if (type == WebServer::POST)
bool repeat;
char name[16], value[16];
do
/* readPOSTparam returns false when there are no more parameters
* to read from the input. We pass in buffers for it to store
* the name and value strings along with the length of those
* buffers. */
repeat = server.readPOSTparam(name, 16, value, 16);
/* this is a standard string comparison function. It returns 0
* when there's an exact match. We're looking for a parameter
* named red/green/blue here. */
if (strcmp(name, "reda") == 0)
/* use the STRing TO Unsigned Long function to turn the string
* version of the color strength value into our integer red/green/blue
* variable */
reda = strtoul(value, NULL, 10);
if (strcmp(name, "greena") == 0)
greena = strtoul(value, NULL, 10);
if (strcmp(name, "bluea") == 0)
bluea = strtoul(value, NULL, 10);
if (strcmp(name, "redb") == 0)
* variable */
redb = strtoul(value, NULL, 10);
if (strcmp(name, "greenb") == 0)
greenb = strtoul(value, NULL, 10);
if (strcmp(name, "blueb") == 0)
blueb = strtoul(value, NULL, 10);
} while (repeat);
// after procesing the POST data, tell the web browser to reload
// the page using a GET method.
server.httpSeeOther(PREFIX);
// Serial.print(name);
// Serial.println(value);
return;
/* for a GET or HEAD, send the standard "it's all OK headers" */
server.httpSuccess();
/* we don't output the body for a HEAD request */
if (type == WebServer::GET)
/* store the HTML in program memory using the P macro */
P(message) =
"<!DOCTYPE html><html><head>"
"<meta charset=\"utf-8\"><meta name=\"apple-mobile-web-app-capable\" content=\"yes\" /><meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge,chrome=1\"><meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">"
"<title>Webduino RGB</title>"
"<link rel=\"stylesheet\" href=\"http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.css\" />"
"<script src=\"http://code.jquery.com/jquery-1.6.4.min.js\"></script>"
"<script src=\"http://code.jquery.com/mobile/1.0/jquery.mobile-1.0.min.js\"></script>"
"<style> body, .ui-page { background: black; } .ui-body { padding-bottom: 1.5em; } div.ui-slider { width: 88%; } #reda, #greena, #bluea { display: block; margin: 10px; } #reda { background: #f00; } #greena { background: #0f0; } #bluea { background: #00f; } </style>"
"<style> body, .ui-page { background: black; } .ui-body { padding-bottom: 1.5em; } div.ui-slider { width: 88%; } #redb, #greenb, #blueb { display: block; margin: 10px; } #redb { background: #f00; } #greenb { background: #0f0; } #blueb { background: #00f; } </style>"
"<script>"
// causes the Arduino to hang quite frequently (more often than Web_AjaxRGB.pde), probably due to the different event triggering the ajax requests
"$(document).ready(function(){ $('#reda, #greena, #bluea').slider; $('#reda, #greena, #bluea').bind( 'change', function(event, ui) { jQuery.ajaxSetup({timeout: 110}); /*not to DDoS the Arduino, you might have to change this to some threshold value that fits your setup*/ var id = $(this).attr('id'); var strength = $(this).val(); if (id == 'red') $.post('/rgb', { red: strength } ); if (id == 'green') $.post('/rgb', { green: strength } ); if (id == 'blue') $.post('/rgb', { blue: strength } ); });});"
"$(document).ready(function(){ $('#redb, #greenb, #blueb').slider; $('#redb, #greenb, #blueb').bind( 'change', function(event, ui) { jQuery.ajaxSetup({timeout: 110}); /*not to DDoS the Arduino, you might have to change this to some threshold value that fits your setup*/ var id = $(this).attr('id'); var strength = $(this).val(); if (id == 'red') $.post('/rgb', { red: strength } ); if (id == 'green') $.post('/rgb', { green: strength } ); if (id == 'blue') $.post('/rgb', { blue: strength } ); });});"
"</script>"
"</head>"
"<body>"
"<div data-role=\"header\" data-position=\"inline\"><h1>Zone A</h1></div>"
"<div class=\"ui-body ui-body-a\">"
"<input type=\"range\" name=\"slider\" id=\"reda\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"greena\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"bluea\" value=\"0\" min=\"0\" max=\"255\" />"
"</div>"
"<div data-role=\"header\" data-position=\"inline\"><h1>Zone B</h1></div>"
"<input type=\"range\" name=\"slider\" id=\"redb\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"greenb\" value=\"0\" min=\"0\" max=\"255\" />"
"<input type=\"range\" name=\"slider\" id=\"blueb\" value=\"0\" min=\"0\" max=\"255\" />"
"</div>"
"</body>"
"</html>";
server.printP(message);
pinMode(REDA_PIN, OUTPUT);
pinMode(GREENA_PIN, OUTPUT);
pinMode(BLUEA_PIN, OUTPUT);
pinMode(REDB_PIN, OUTPUT);
pinMode(GREENB_PIN, OUTPUT);
pinMode(BLUEB_PIN, OUTPUT);
// setup the Ehternet library to talk to the Wiznet board
Ethernet.begin(mac, ip);
/* register our default command (activated with the request of
* http://x.x.x.x/rgb */
webserver.setDefaultCommand(&rgbCmd);
/* start the server to wait for connections */
webserver.begin();
// process incoming connections one at a time forever
webserver.processConnection();
Serial.print(reda);
Serial.print(" ");
Serial.print(greena);
Serial.print(" ");
Serial.println(bluea);
Serial.print(redb);
Serial.print(" ");
Serial.print(greenb);
Serial.print(" ");
Serial.println(blueb);
analogWrite(REDA_PIN, reda);
analogWrite(GREENA_PIN, greena);
analogWrite(BLUEA_PIN, bluea);
analogWrite(REDB_PIN, redb);
analogWrite(GREENB_PIN, greenb);
analogWrite(BLUEB_PIN, blueb);
