Hi noobie here, not sure if this is the correct forum,
Have a code loaded on a Arduino and can control either the Pan or Tilt as long as only I pin is connected as soon as I connect the 2nd or 3rd pin the mount stops responding.
Is there something in the code I am missing or my pinout connections.
I tried 3 different Nanos with the same result.
#define left 11 // Pin 12 controls left pan
#define right 10 // Pin 10 controls right pan
#define down 12 // Pin 9 controls down tilt
#define up 9 // Pin 8 controls up tilt
#define zoomin A0 // Pin A0 controls Zoom In
#define zoomout A1 // Pin A1 controls Zoom Out
#define zoom 4 // Pin 4 connected to RC receiver channel 3 which controls Zoom
#define receiver 3 // Pin 3 connected to RC receiver channel 1 which controls Tilt
#define receiver2 2 // Pin 2 connected to RC receiver channel 2 which controls Pan
// Note that Pin 5 is connected to RC receiver channel 4 but is not used in this code
// Variables to hold the RC Receiver received values
int ch1 = 0;
int ch2 = 0;
int ch3 = 0;
// Set the Pin modes
pinMode(receiver, INPUT);
pinMode(receiver2, INPUT);
pinMode(zoom, INPUT);
pinMode(left, OUTPUT);
pinMode(right, OUTPUT);
pinMode(down, OUTPUT);
pinMode(up, OUTPUT);
pinMode(zoomin, OUTPUT);
pinMode(zoomout, OUTPUT);
//Write all pins LOW at start
digitalWrite(up, LOW);
digitalWrite(down, LOW);
digitalWrite(left, LOW);
digitalWrite(right, LOW);
digitalWrite(zoomin, LOW);
digitalWrite(zoomout, LOW);
// Get current values of RC Receiver Channels
ch1 = pulseIn(receiver, HIGH, 20000);
ch2 = pulseIn(receiver2, HIGH, 20000);
ch3 = pulseIn(zoom, HIGH, 20000);
// Tilt based on the input from the Right (Up-Down movement) joystick from the RC Transmitter
if (ch1 < 1200) // Transmitter Joystick pushed UP
digitalWrite(up, HIGH);
//analogWrite(up, 255); // Move the Bescor MP-101 Camera Tilt UP
else if (ch1 > 1700) // Tranmitter Joystick pushed DOWN
//analogWrite(down, 255); // Move the Bescor MP-101 Camera Tilt DOWN
digitalWrite(down, HIGH);
else // Put pins LOW to stop Tilt movement of Bescor MP-101
// Pan based on the input from the Right (Left-Right movement) joystick from the RC Transmitter
if (ch2 < 1200) // Transmitter Joystick pushed Left
digitalWrite(left, HIGH); // Move the Bescor MP-101 Camera Pan LEFT
else if (ch2 > 1700) // Transmitter Joystick pushed RIGHT
digitalWrite(right, HIGH); // Move the Bescor MP-101 Camera Pan RIGHT
else // Put pins LOW to stop Pan movement of Bescor MP-101
// Zoom based on the input from the Left (Up-Down movement) joystick from the RC Transmitter
if (ch3 < 1000) // Transmitter Joystick pushed UP
digitalWrite(zoomin, HIGH); // Simulate pushing the Zoom IN tact switch on the eBenk LANC remote
else if (ch3 > 2000) // Transmitter Joystick pushed DOWN
digitalWrite(zoomout, HIGH); // Simulate pushing the Zoom OUT tact switch on the eBenk LANC remote
else // Put pins LOW to stop ZOOM
