Hello I am trying to control PWM with the touch of a button here is my code:
#include <Button.h>
ArduKart
This program was written for an Arduino powered GoKart.
Press GO and the kart with ramp up to top speed
This is done trough PWM to a motor controller
Press REV and the kart will go into reverse with a preset max speed
This is also done through PWM to a motor controller
Button goButton(7,PULLDOWN);
int ledPin = 10; // LED connected to digital pin 9
byte goPos = 0; //loop counter
When I press to Go button I want the PWM signal to ramp up to 255 and when I let go of the Go button I want the counter to reset. As of now, when I reach 255 the loop repeats! I just want it to stay at 255 when it is reached. I am having a hard time figuring out what to use - a FOR, WHILE, etc. I am pretty new to this so any help would be greatly appreciated
int goPos = 90; //puts motor controllers @ 90 degrees (neutral)
int revPos = 90; //puts motor controllers @ 90 degrees (neutral)
int rampSpeed = 100; //time it takes to ramp up to full speed
Serial.begin (9600);
leftMotor.attach(9); // left motor controller connected to digital pin 9
rightMotor.attach(10); // right motor controller connected to digital pin 10
pinMode(gndPin, OUTPUT);
delay(100); //delay for testing
if(goButton.isPressed())
if (goPos < 180) {goPos ++;}
if (goPos > 180) {goPos = 180;}
leftMotor.write(goPos);
rightMotor.write(goPos);
delay(rampSpeed);
if(revButton.isPressed())
if (revPos <= 90) {revPos --;}
if (revPos < 0) {revPos = 0;}
leftMotor.write(revPos);
rightMotor.write(revPos);
goPos = 90;
revPos = 90;
I am using two SPST pushbutton switches connected to digital in 7 & 8 common pull-down resistor and common 5v. They seem to be interfering with each other. When I press Go the Go counter counts up from 90 and the Reverse counter counts down from 90. I need them to act totally independently. When I press go the go counter could from 90 to 180 and when I press Rev. I need to count from 90 to 0. I also need to make it so it I accidently press both buttons don't send both sets of numbers to the motor controllers. In fact if I had 1 counter, that would be the counter to send to the motor controllers. I don't know its getting late and I want to figure it out but I just can't.
Do I need to isolate my inputs? - using diodes???
Do I need to have 2 counters?
LOL thanks for the advice! I'm not trying to save resistors I am trying to save my gnd pins! Anyways some real advice would be nice. How can I isolate my 2 switches - can it be done in programming or does it have to be hardware?
