Trying to Count using an IR Breakbeam Sensor
I am trying to count the number of breaks an IR sensor has while running a servo motor at the same time and when the number of counts is finished, the servo stops. The code I am using is:
#include <Servo.h>
Servo myservo;
int potpin = 0;
int val;
int currentCount = 0;
int endCount = 1;
#define LEDPIN 13
#define SENSORPIN 4
int sensorState = 0, lastState=0;
  myservo.attach(9);
  pinMode(LEDPIN, OUTPUT);
  pinMode(SENSORPIN, INPUT);
  digitalWrite(SENSORPIN, HIGH);
  sensorState = digitalRead(SENSORPIN);
  if (currentCount < endCount) {
    Serial.println("Starting Count less than End Count");
    val = analogRead(potpin);
    val = map(val, 0, 1023, 1000, 2000);
    myservo.writeMicroseconds(val);
    delay(1500);
    if (sensorState && !lastState) {
      currentCount = currentCount +1;
      Serial.println(currentCount);
    //if IR Sensor is broken +1 to current count
  else {
    Serial.println("Done Counting " + currentCount);
    // stop moving the sensor
    val = map(val, 0, 0, 0, 0);
I am trying to double check by having it print start count and each time the IR breaks the count adds one. Currently the beginning starts out well but once the IR breaks once, this prints out rapidly:
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
one Counting
After that it no longer can count anymore. Is it an issue that I used an if else statement? Do you guys have any suggestions? Thank you for the help.
Have a look at the state change example in the IDE - you're missing something     if (sensorState && !lastState)
Would this work better? I looked at the IDE and added in the parts I'm missing:
    delay(1500);
    if (sensorState == LOW) {
    // turn LED on:
    digitalWrite(LEDPIN, HIGH);
    else {
    // turn LED off:
    digitalWrite(LEDPIN, LOW);
      delay(1500);
    if (!sensorState && lastState) {
    Serial.println("Sensor has broken");
    lastState = sensorState;
  else {
    Serial.println("Done Counting ");
    // stop moving the servo
Why are you asking us? You're the one with the hardware to test it.
If you actually looked at the map() function, you know just how stupid that call is.
