I am using the Arduino Uno R3 to store audio data into an SD card and then send the data with Wifi. this is the code I am using to create the web server:
#include <SoftwareSerial.h>
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#include <ESPAsyncWebServer.h> // Include the AsyncWebServer library
SoftwareSerial client(2, 3); // RX, TX
String webpage = "";
int i = 0, k = 0;
String readString;
int x = 0;
boolean No_IP = false;
String IP = "";
char temp1 = '0';
String name = "<p>Circuit Digest</p>"; // 22
String dat = "<p>Data Received Successfully.....</p>"; // 21
AsyncWebServer server(80); // Create an AsyncWebServer instance
void check4IP(int t1)
int t2 = millis();
while (t2 + t1 > millis())
while (client.available() > 0)
if (client.find("WIFI GOT IP"))
No_IP = true;
void get_ip()
IP = "";
char ch = 0;
while (1)
client.println("AT+CIFSR");
if (client.find("STAIP,"))
delay(10000);
Serial.print("IP Address:");
ch = client.read();
if (ch == '+')
IP += ch;
if (ch == '+')
if (ch == '+')
delay(10000);
Serial.print(IP);
Serial.print("Port:");
Serial.println(333);
void connect_wifi(String cmd, int t)
int temp = 0, i = 0;
while (1)
Serial.println(cmd);
client.println(cmd);
while (client.available())
if (client.find("OK"))
i = 8;
delay(t);
if (i > 5)
i++;
if (i == 8)
Serial.println("OK");
Serial.println("Error");
void wifi_init()
connect_wifi("AT", 100);
connect_wifi("AT+CWMODE=3", 100);
connect_wifi("AT+CWQAP", 100);
connect_wifi("AT+RST", 5000);
check4IP(5000);
if (!No_IP)
Serial.println("Connecting Wifi....");
connect_wifi("AT+CWJAP_CUR=\"The Matrix\",\"Rogers1021\"", 7000); // provide your WiFi username and password here
// connect_wifi("AT+CWJAP=\"vpn address\",\"wireless network\"",7000);
Serial.println("Wifi Connected");
get_ip();
connect_wifi("AT+CIPMUX=1", 100);
connect_wifi("AT+CIPSERVER=1,333", 100);
void sendwebdata(String webPage)
int ii = 0;
while (1)
unsigned int l = webPage.length();
Serial.print("AT+CIPSEND=0,");
client.print("AT+CIPSEND=0,");
Serial.println(l + 2);
client.println(l + 2);
delay(100);
Serial.println(webPage);
client.println(webPage);
// Serial.print(Serial.read());
ii = 11;
if (ii == 11)
delay(100);
client.begin(115200);
wifi_init();
Serial.println("System Ready..");
// Initialize the SD card
if (!SD.begin(4)) {
Serial.println("SD failed");
return;
Serial.println("SD OK");
// Set up a route for serving the audio file
server.on("/playaudio", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(SD, "/test2.wav", "audio/wav");
// Start the web server
server.begin();
I am currently getting an error that is:
- In file included from C:\Users\Shane\Desktop\Fourth Year\ELE 70A\code\Automatic_Wifi\Automatic_Wifi.ino:5:0: c:\Users\Shane\Documents\Arduino\libraries\AsyncTCP\src/AsyncTCP.h:26:10: fatal error: sdkconfig.h: No such file or directory
#include "sdkconfig.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
I have tried downloading a sdkconfig.h file into the directory and reinstalling the ESP8266 core, none of which have worked. Does anyone have any idea/solutions for this? Thank you.
