Trying to create an iota transaction bundle in C
I am trying to create an iota transaction bundle in C for Arduino devices and created therefore a github repository:
The code is compiling successfully, however the Arduino is making some encrypted outputs that doesn't make any sense. I am not able to limit the problem to one file, due to lack of knowladge in c. I suspect that the problem could be in the following files:
kerl.h, kerl.c, conversion.h, conversion.c
I hope you can help me with this problem. Thanks for any help in advance.
PS: I am using the Arduino IDE to compile the code. I think it could be a pointer/stack problem?
The code does something that you have woefully-inadequately defined. What does it REALLY do?
You expect it to do something that you have kept a secret. That doesn't work here.
Why do you think that?
First of all thank you for your reply.
I am trying to get something that is so called "bundle hash bundle". It looks like the following:
Transaction object:
"hash": "FOUXA9MWUAETQRWDMZ9CWFX9FBGSOIYD9TCTJBDYKLFSGWGEIAQKBVAXMLSAALBPSZPBMDJF9KTLDX999",
"signatureMessageFragment": "999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999",
"address": "CNBDVRFPLTZDCONTTLIWHPQANGLIDSTAZDLFVRJEJE9CJVUCXNAFSWASGZWGXKAURXEDPINCVUTVZHFSC",
"value": 9999629,
"obsoleteTag": "999999999999999999999999999",
"timestamp": 1527598532,
"currentIndex": 3,
"lastIndex": 3,
"bundle": "MJYOZGDEVIQKZPXPVJFCWGRESRGXVGOEJEZHQLKVSPSLOE9OLFROGCEUURKZDYIGFKIIPKDLXFJPGTHNZ",
"trunkTransaction": "DARJFGSEOHSMZKCHUVRKGOCVBFA9NTIMVPIPQACKJIYSFOVUTWOWHY9GOELYRWEVFFDPNTVPHCHIFW999",
"branchTransaction": "ICRKPKSIVZHURDPSPJGWNCWCCAENRDZDNVYQPCEAIYOXGVDYUTV9BIUHXL9DDWIQJAYQXQUTLVBMA9999",
"tag": "999999999999999999999999999",
"attachmentTimestamp": 1527598533627,
"attachmentTimestampLowerBound": 0,
"attachmentTimestampUpperBound": 3812798742493,
"nonce": "WZ999I999999999999999999999"
Transaction object converted into trytes:
999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999CNBDVRFPLTZDCONTTLIWHPQANGLIDSTAZDLFVRJEJE9CJVUCXNAFSWASGZWGXKAURXEDPINCVUTVZHFSCQYAVSA999999999999999999999999999999999999999999999999KFALLYD99C99999999C99999999MJYOZGDEVIQKZPXPVJFCWGRESRGXVGOEJEZHQLKVSPSLOE9OLFROGCEUURKZDYIGFKIIPKDLXFJPGTHNZDARJFGSEOHSMZKCHUVRKGOCVBFA9NTIMVPIPQACKJIYSFOVUTWOWHY9GOELYRWEVFFDPNTVPHCHIFW999ICRKPKSIVZHURDPSPJGWNCWCCAENRDZDNVYQPCEAIYOXGVDYUTV9BIUHXL9DDWIQJAYQXQUTLVBMA9999999999999999999999999999999ROYDZ9AKE999999999MMMMMMMMMWZ999I999999999999999999999
Transaction object trytes length: 2673
Transaction object timestamp: 29 May 2018 12:55:32
but everything that i get from the serial.println is a reversed questionmark. The main funktion is the "transaction.ino" if you like you can test it yourself.
"Why do you think that?"
because I read online that there appears some encrypted outputs if you have some pointer or stack issues.
Are you really trying to store 2673 bytes in SRAM at one time? Or more? On which Arduino?
tryte_t bundle_hash_out[10];
where is the end of the array?
for(int i = 0; i<100; i++)
  Serial.print(bundle_hash_out[i]);
what happens when you go past the end of the array?
Thank you everybody for helping. I really appreciating it! You are awsome!
I have investigeted more and now I know that the function kerl_absorb_trit (when calling the keccak_update) in the kerl.c isn't working. When I comment the function for testing everything works fine. Maybe I am giving the function wrong values?
