Trying to create simple menu using lcd display
Ok so I am very new to this and I have this program that well the lcd flickers on "Menu" but no big deal there and I manage to when I press the button it changes my display to menu2 but in my menu2 i am not able to return to Menu I tried using the same program I used to toggle my button in my Menu section for it to go to Menu2 but that just messed my code and the lcd starts displaying both menus so is there a way to return from 1 menu to the other I tried using switch cases but run with the same issue I am able to enter the subMenu but the return does not work
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 6, 8, 10);
int button = 12;
int buttonState;
unsigned long buttonDown;
int Exit = 13;
int ExitState;
unsigned long buttonDown2;
int mod = 0;
  lcd.begin(16,2);
  pinMode(button, INPUT_PULLUP);
  pinMode(Exit, INPUT_PULLUP);
  lcd.setCursor(5,0);
  lcd.print("Welcome");
  delay(2000);
void MENU(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu1");
  while(buttonState == LOW){
  buttonDown = millis(); //record the time the button went down
  while(!buttonState) {
     //wait until the button is released
    if(millis()-buttonDown>100) {
      //button was held for 0.1 seconds
      MENU2();
      break;  //leave the loop
void MENU2(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu2");
  while(ExitState == LOW){ //wait until the button is pushed (active-low, so TRUE=not pushed)
  buttonDown2 = millis(); //record the time the button went down
  while(!ExitState) {
    if(millis()-buttonDown2>100) {
      MENU();
  buttonState = digitalRead(button);
  ExitState = digitalRead(Exit);
  MENU();
If you're new, you'll have a hard time making out your own menu, and most of the time I can't think of any benefits.
I highly suggest looking into many different menu management libs available out there and choose one.
Recently I had such a dilemma and settled down with LiquidMenu which was perfect for my use case and pretty simple to use.
You can see how I used it in my last project: Airsoft bomb prop - Kulverstukas's blog
Not tested, but I would personally change the code slightly to something like this: Use a variable to check what page you are on, and only refresh the LCD when a change is made (this should stop your flickering).
int button = 12;
int buttonState;
int Exit = 13;
int ExitState;
int mod = 0;
int pageDisplayed=0;
boolean pageChanged = false;
  lcd.begin(16,2);
  lcd.setCursor(5,0);
  delay(2000);
void Menu1(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu1");
void Menu2(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu2");
void Menu3(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu3");
        pageDisplayed++;             // increment the page to display
        if (pageDisplayed>3) pageDisplayed=1;
        pageChanged=true;
  if (pageChanged) {
    pageChanged=false;             // reset page changed flag so only refresh the page when needed
    switch(pageDisplayed) {
      case 1:                      // page 1 chosen
        Menu1();
      case 2:                      // page 2 chosen
        Menu2();
       case 3:                     // page 3 chosen
        Menu3();
       default:                    // something went wrong - invalid page, so set and show page 1
        pageDisplayed=1;
        Menu1;
Thanks @dh68 I understand where this is going and going to see if it works for me but I just tried and it just displays the welcome and nothing else so I am going to check on this and @kulverstukass I tried just looking for a menu template but it gets to complicated for me since I need to include some sensors later on and on the ones that are already built I have a hard time where to edit and start including my program
No worries - Not got too much time to investigate at the moment but I think its the button de-bounce that is wrong. Here's a slightly more crude but simple version: Give this a bash - should be a good starting point. Also added some serial print statements for debugging that should help show what's going on
int button = 12;
int buttonState;
unsigned long buttonDown = 0;
int Exit = 13;
int ExitState;
int mod = 0;
  lcd.begin(16,2);
  lcd.setCursor(5,0);
  Serial.println("Welcome");
void Menu1(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu1");
  Serial.println("Menu 1");
void Menu2(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu2");
  Serial.println("Menu 2");
void Menu3(){
  lcd.clear();
  lcd.setCursor(5,0);
  lcd.print("Menu3");
  Serial.println("Menu 3");
void checkButton()
  if(buttonState == LOW){
    Serial.println("Button Down!");
    while (digitalRead(button)==LOW)
      Serial.println("button still pressed - wait for release!");
    Serial.println("Button released");
    pageChanged=true;
    buttonDown=millis();
  checkButton();
  if (pageChanged) {
        Menu1();
        Menu2();
        Menu3();
        pageDisplayed=1;
        Menu1();
  // Do what ever else you want here
  // like read sensors, etc
Thanks a lot dh68 I am going to work on this tomorrow to see if it works for me that way I can continue with the full project but thaks for the help
Note.
The use of common punctuation like periods, commas and so forth, as well as
line breaks,
is allowed and even encouraged on these fora.
a7
Ok noted alto777
And thanks a lot dh68 with this menu system i can now start working on my complete project I need to add a couple of sensors and work on some stuff but with the menu I can work on this thanks
I´ll probably be back once I get my sensors and start constructing my ventilator since that is my project but thanksa lot for the help
Hey @dh68 quick question here and don´t know if you would know
But I made some changes to the code just on what is displayed and decided to use tinkercad to add my temperature sensor since the one on tinkercad is the one I am going to use the tmp36, ok so I added it and it displays my temp but it does not update it if I change the temperature value I mean if I change from menu1 to menu2 it updates but is there a way for it to update while on menu1 without changing displays
I leave my code and my setup from tinkercad I am going to be working on this but any tips highly appreciated
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int buttonRight = 9;
int buttonRightState;
int buttonLeft = 10;
int buttonLeftState;
  lcd.begin(16,2);
  pinMode(buttonRight, INPUT_PULLUP);
  pinMode(buttonLeft, INPUT_PULLUP);
  lcd.setCursor(0,0);
  lcd.print("Sistema de Altos");
  lcd.setCursor(5,1);
  lcd.print("Flujos");
void Menu1(){
  float voltageT = analogRead(A0) * 0.004882814;
  float degreesC = (voltageT - 0.5) * 100.0;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Temp=    C");
  lcd.setCursor(5,0);
  lcd.print(degreesC);
  lcd.setCursor(0,1);
  lcd.print("Flujo=25Lpm ");
void Menu2(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("FiO2= ");
void Menu3(){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Flujo= ");
void checkButton() {
  buttonRightState = digitalRead(buttonRight);
  buttonLeftState = digitalRead(buttonLeft);
  if(buttonRightState == LOW){
    while (digitalRead(buttonRight)==LOW)
    pageChanged=true;
  if(buttonLeftState == LOW){
    while (digitalRead(buttonLeft)==LOW)
    pageDisplayed--;             // decreases the page to display
    if (pageDisplayed<1) pageDisplayed=3;
    pageChanged=true;
  checkButton();
  if (pageChanged) {
        Menu1();
        Menu2();
        Menu3();
        pageDisplayed=1;
        Menu1();
And also a question I need to place values in menu 2 and 3 and have them displayed on menu1 is this possible? I am going to try to add like a counter on menu 2 and 3 for now since I dont have sensors and want the number that is in the counter in menu 2 to be displayed also in menu 1 is there like a way for this with the code that I have right now?
