Arduino is a NodeMCU
and here is the code. I hate it when the sketch has errors and this had a lot caused by the #include files being missing.
After I put in what I thought was the proper #Include files, I still get an error which is the 2nd item I have listed. Sheesh.
Display sensor calibration status
#include <Adafruit_GPS.h>
#include <Adafruit_BNO055.h>
#include "Sensor.h"
void displayCalStatus(void)
/* Get the four calibration values (0..3) */
/* Any sensor data reporting 0 should be ignored, */
/* 3 means 'fully calibrated" */
uint8_t system, gyro, accel, mag;
system = gyro = accel = mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
/* The data should be ignored until the system calibration is > 0 */
Serial.print("\t");
if (!system)
Serial.print("! ");
/* Display the individual values */
Serial.print("Sys:");
Serial.print(system, DEC);
Serial.print(" G:");
Serial.print(gyro, DEC);
Serial.print(" A:");
Serial.print(accel, DEC);
Serial.print(" M:");
Serial.println(mag, DEC);
Error listing
Arduino: 1.8.5 (Linux), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
/home/hexdump/Arduino-1.8.5/Sketches/BNO055-Status/BNO055-Status.ino: In function 'void displayCalStatus()':
BNO055-Status:17: error: 'bno' was not declared in this scope
Multiple libraries were found for "SoftwareSerial.h"
Used: /home/hexdump/.arduino15/packages/esp8266/hardware/esp8266/2.6.3/libraries/SoftwareSerial
Not used: /home/hexdump/Arduino-1.8.5/Sketches/libraries/EspSoftwareSerial
exit status 1
option enabled in File -> Preferences.
