I'm trying to tweak some code that I found but I'm not having much luck. I'm trying to get something up and running to protect my koi pond. There is a blue heron that keeps showing up trying to eat my koi. It already got one of them. I've been getting up at 5am and watch over the pond waiting for the bird to show up and scare it. As much as I would love to do some harm, it's illegal and only looking to activate a water sprinkler and a radio.
The tripwire will be activating a water valve and a radio. I would like to use the code below but add a few features that if the sensor gets blocked the water wouldn't be running all day and when tripped it only outputs water for few seconds.
When in the armed state-- When the laser beam gets interrupted output for 15 seconds and then rearm itself, while keeping the arm and disarm button
(I didn't have much luck with delay or timer.h) -
When in the armed state-- if laser beam gets interrupted say 3 times within 45 seconds - 1 minute- disable alert led and buzzer and play a different tone or flash an led of problem. (if something falls out of alignment- water,radio,etc isn't running all day.)
Any tips on what function I should search for and try to implement? Thanks
* Laser trip wire
* v 1.3
* by: Keith Kay
* 1/31/2013
* CC by-sa v3.0 - http://creativecommons.org/licenses/by-sa/3.0/
* http://keithkay.com
* Laser trip-wire sketch which implements the following functionality:
* - Calibration to current light environment
* - Visual feedback on alignment
* - Arming and disarming mechanism
* attribution: siren code modified from
* Annoying siren
* CC by-sa v3.0
* http://tronixstuff.wordpress.com
// first define the constants used for sensor / emitter pins
const int triggeredLED = 7; // pin for the warning light LED
const int RedLED = 3; // pin for the 'armed' state indicator
const int GreenLED = 4; // pin for the 'un-armed' state indicator
const int inputPin = A0; // pin for analog input
const int speakerPin = 12; // pin for the speaker output
const int armButton = 6; // pin for the arming button
// define variables used for readings and programatic control
boolean isArmed = true; // variable for the armed state
boolean isTriggered = false; // has the wire been tripped
int buttonVal = 0; // variable to store button state and compare with previous
int prev_buttonVal = 0; // variable to 'debounce' button
int reading = 0; // variable to store the analog value coming from the sensor
int threshold = 0; // variable set by the calibration process
// constants used for the siren
const int lowrange = 2000; // the lowest frequency value to use
const int highrange = 4000; // the highest...
void setup(){
// configure LEDs for output
pinMode(triggeredLED, OUTPUT);
pinMode(RedLED, OUTPUT);
pinMode(GreenLED, OUTPUT);
//configure the button for input
pinMode(armButton, INPUT);
// for debugging and calibration review
Serial.println("");
Serial.println("Initializing...");
// intial 'test' to be sure all LEDs and the speaker are working
digitalWrite(triggeredLED, HIGH);
digitalWrite(triggeredLED, LOW);
Serial.println("Unarmed");
setArmedState();
Serial.println("Armed");
setArmedState();
// calibrate the laser light level in the current environment
// this was moved to a function for future integration of a reset function
calibrate();
// start unarmed
setArmedState();
void loop(){
// read the LDR sensor
reading = analogRead(inputPin);
// check to see if the button is pressed
int buttonVal = digitalRead(armButton);
if ((buttonVal == HIGH) && (prev_buttonVal == LOW)){
setArmedState();
Serial.print("button val= ");
Serial.println(buttonVal);
// print the value to serial
Serial.print("Reading = ");
Serial.println(reading);
// check to see if the laser beam is interrupted based on the threshold
if ((isArmed) && (reading < threshold)){
isTriggered = true;}
if (isTriggered){
// siren code
// increasing tone
for (int i = lowrange; i <= highrange; i++)
tone (speakerPin, i, 250);
// decreasing tone
for (int i = highrange; i >= lowrange; i--)
// flash LED
delay(10);
// short delay - if you are debugging a modification you may want to increase this to slow down the serial readout
delay(20);
// function to flip the armed state of the trip wire
void setArmedState(){
if (isArmed){
digitalWrite(GreenLED, HIGH);
digitalWrite(RedLED, LOW);
isArmed = false;
digitalWrite(GreenLED, LOW);
digitalWrite(RedLED, HIGH);
tone(speakerPin, 220, 125);
delay(200);
tone(speakerPin, 196, 250);
isArmed = true;
void calibrate(){
int sample = 0; // array to hold the initial sample
int baseline = 0; // variable to set the baseline reading
const int min_diff = 200; // minimum difference needed between current light level and laser calibration
const int sensitivity = 50;
int success_count = 0;
// ensure both LEDs are off
// start by taking a 10 reading sample, then take the average for our baseline
for (int i=0; i<10; i++){
sample += analogRead(inputPin); // take reading and add it to the sample
delay (50); // delay to blink the LED and space readings
// calculate and print the baseline
baseline = sample / 10;
Serial.print("baseline = ");
Serial.println(baseline);
// now keep taking a reading until we've gotten 3 successful reads in a row
do
sample = analogRead(inputPin); // this time we work with one reading at a time
if (sample > baseline + min_diff){
success_count++;
threshold += sample;
delay (100); // delay to blink the LED and space readings
success_count = 0; // this give us the 'in a row' result
threshold = 0;
} while (success_count < 3);
//lastly we need to correctly set the threshold as it now hold the sum of 3 samples
threshold = (threshold/3) - sensitivity;
// play the arming tone and in reverse and print the threshold to condfrim threshold set
delay(200);
^ pulled from here arduino/Arduino Laser Tripwire at master · keithkay/arduino · GitHub
A video from the creator in operation if it helps anyone understand it all.
