Trying to establish a counter with multiple buttons
Hello!
I’m trying to make a project with this situation.
There are 6 push buttons that can be pressed.
When I press one button a counter will show 1 on the screen and it will continue showing one until it is released, when released it must show 0.
And The same, if I press two buttons or three or four it must show the number of buttons pressed, and update continuously, for example if I press three buttons but I release only one it must show two on the counter.
I had previously researched but I can‘t find something similar...
How can I make this in code?
I will appreciate a lot your help. Thank you.
See attached numButtons.ino
The delay(100) in loop() act as a crude debouncer. If you need faster refresh then it needs a better debouncing
numButtons.ino (551 Bytes)
Do post your current best attempt.
This has all the hallmarks of a school assignment, isn't it?
