Trying to find a code and maybe some help on how to run a servo?
Trying to run an HS-81 HItech servo
This is the reference for the Servo library : http://arduino.cc/en/reference/servo
There are two links for examples.
Basic servo test code:
// zoomkat 12-25-13 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// Send an a to attach servo or d to detach servo
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
String readString; //String captured from serial port
Servo myservo;  // create servo object to control a servo
int n; //value to write to servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7, 500, 2500);  //the pin for the servo control, and range if desired
  Serial.println("servo all-in-one test code 12-25-13"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
      // attach or detach servo if desired
    if (readString == "d") {
      myservo.detach(); //detach servo
      Serial.println("servo detached");
      goto bailout; //jump over writing to servo
    if (readString == "a") {
      myservo.attach(7); //reattach servo to pin 7
      Serial.println("servo attached");
      goto bailout;
    n = readString.toInt();  //convert readString into a number
    // auto select appropriate value
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
bailout: //reenter code loop
    Serial.print("Last servo command position: ");
    Serial.println(myservo.read());
    readString=""; //empty for next input
xxfranklinhxx:
Google Arduino servo ? ?
...R
Do not power the servo from the Arduino because it is likely to use too much current. Power it from an external source with a common GND connection.
