trying to find a DB25M to DB25F bulkhead/panel mount
ok, so on my CNC, the breakout boards (i have two of them) connect to the computer via a DB25M to DB25F cable (not printer, as those have a Centronics connector for the printer end). the breakout boards are inside a metal cabinet, and i need to be able to close the cabinet door to keep dust out. if i could find some bulkhead/panel pass through connectors, it would solve that problem. i have racked my brain for quite some time, looking for them (since starting the CNC). i have searched eBay, and Amazon, just searched google images again. the best i could find was a DB25 gender changer, but i am not sure if i could make that work.
Just probing the great minds.
~Travis
Google gland connector.
This seems like a good fit for the "General Electronics" forum.
But, you knew this already.
The operative word is:
General
Maybe use a panel mount with IDC connector, then crimp on whatever sex connector you need on the inside
https://www.digikey.com/products/en/connectors-interconnects/d-sub-connectors/439?k=db25&k=&pkeyword=db25&pv69=4&FV=ffe001b7&mnonly=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
