Trying to find an Arduino project...
I'm not sure if this is the right place to post this; I'm sortof seeking some "Lost & Found" type help.
A year or two ago, I stumbled across an article on the web; the author showed a build log and some snippets of code where he had used an arduino to balance brushless motors used for RC aircraft.
His setup was crude, yet elegant in its simplicity; the code self-attenuated the signal, and he used an arduino to trigger an LED strobe to identify the heavy side of a brushless motor loosely screwed to a board with one leg resting on a piezo disc as a sensor.
He described the working of the device, IIRC, as "triggering the strobe at 90° to the angle of the hinge" or somesuch. This is all I can remember; unfortunately after searching for hours for "arduino motor balancing" the article I'm looking for is either gone or drowned out by a sea of "arduino self-balancing robots" related articles. I'm hoping someone here somewhere made note of this article, and either has saved it or a current link to it.
Thank you for your time,
Paul in "The middle of Nowhere, TX"
https://techtv.mit.edu/videos/18113-pcb-quadrotor-strobe-vibration-visualization
Any help?
This also look kinda promising:
http://diydrones.com/forum/topics/balancing-propellors-and-motors?id=705844%3ATopic%3A1011737&page=1#comments
Are you trying to build a balance unit too?
The MIT article I'm familiar with; I actually have a video on youtube about using common LED flashlights as a strobe to help diagnose vibrations in microheli frames, etc.
https://www.youtube.com/watch?feature=player_detailpage&v=X3cAdFU659Y&list=UUz4lBtijx6COKevVMuv7QuA
The second one sounds a bit closer; at least he's on about balancing the right kind of thing. But it's really not the thing I'm looking for. His method requires making a jig for every armature; the elegance of this guy's setup is that it uses the motor itself as it's own power source, so it gets a truly dynamic balance of the motor exactly as it is going to be used. One can even, in theory, balance the props right along with it.
Dang. I REALLY wish I'd saved that whole web page to my hard drive...
I wish my kung-fu weren't so weak; I know how he BUILT it. I just have no clue where to even begin to program it.
I guess I'll have to build it and then see if I can get some help with the software.
mnem Drop back & punt
