Trying to flash text on SSD1306 OLED screen
Not sure what I am doing wrong here. I am trying to just alternate a string back and forth on the SSD1306 oled screen.
I want the display to show “test1” for 0.5 seconds, then “test2” for 0.5 seconds. the code below is just showing “test1” for 0.5 seconds then going blank…
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  display.clearDisplay();
  // Show the display buffer on the screen. You MUST call display() after
  // drawing commands to make them visible on screen!
  display.display();
  delay(2000);
  display.setTextSize(4);             // Draw 2X-scale text
  display.setTextColor(SSD1306_WHITE);
 testdrawstyles1();
 testdrawstyles2();
void testdrawstyles1(void) {
 display.print(F("test1"));
 display.display();
void testdrawstyles2(void) {
 display.print(F("test2"));
 display.display();
You have’t set the cursor position that might be the answer eg
display.setCursor(0,0);
