Trying to get a longer tone out of this code
#include <math.h>
int digit_pin[] = {6, 9, 10, 11}; // PWM Display digit pins from left to right
int speakerPin = 34;
int ledpin = 34;
#define DIGIT_ON LOW
#define DIGIT_OFF HIGH
int segA = 2;
int segB = 3;
int segC = 4;
int segD = 5;
int segE = A0; //pin 6 is used bij display 1 for its pwm function
int segF = 7;
int segG = 8;
//int segPD = ;
int button1=13;
int button2=12;
int button3=16;
int button4=17;
int countdown_time = 60;
struct struct_digits {
int digit[4];
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
for (int i=0; i<4; i++) {
pinMode(digit_pin[i], OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(button1,INPUT_PULLUP);
pinMode(button2,INPUT_PULLUP);
pinMode(button3,INPUT_PULLUP);
pinMode(button4,INPUT_PULLUP);
void playTone(int tone, int duration) {
for (long k = 0; k < duration * 1000L; k += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone):
digitalWrite(speakerPin, LOW);
delayMicroseconds(tone);
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
case 3:
case 4:
case 5:
digitalWrite(segB, SEGMENT_OFF);
case 6:
case 7:
case 8:
case 9:
case 10:
void SwitchDigit(int digit) {
if (i == digit) {
digitalWrite(digit_pin[i], DIGIT_ON);
digitalWrite(digit_pin[i], DIGIT_OFF);
struct struct_digits IntToDigits(int n){
struct struct_digits dig;
int zeros=0;
int d;
d=n/pow(10,3-i);
zeros += d;
n = n - d*pow(10,3-i);
if (zeros!=0 || i==3) {
dig.digit[i]=d;
dig.digit[i]=10;
return dig;
void PrintNumber(int n, int time) {
dig = IntToDigits(n);
for (int i=0; i<= time/20; i++) {
if (digitalRead(button2)==LOW) {
return;
for (int j=0; j<4; j++) {
SwitchDigit(j);
lightNumber(dig.digit[j]);
delay(5);
bool Countdown(int n, int del){
for (int q=n; q>0; q--){
PrintNumber(q,del);
return false;
PrintNumber(0,0);
playTone(1519,1000);
return true;
void reset() {
int m, zeros, d, pressed3 = 0, pressed4 = 0;
m=countdown_time;
dig = IntToDigits(countdown_time);
while (digitalRead(button1)==HIGH) {
SwitchDigit(j);
delay(5);
if (digitalRead(button3)==LOW) {
if (pressed3 == 0 || pressed3 > 30) {
if (countdown_time > 0) {
countdown_time -= 1 ;
pressed3 += 1;
else if (digitalRead(button4)==LOW) {
if (pressed4 == 0 || pressed4 > 30) {
if (countdown_time <9999) {
countdown_time += 1 ;
pressed4 += 1;
if (digitalRead(button3)==HIGH) {
pressed3=0;
if (digitalRead(button4)==HIGH) {
pressed4=0;
void loop(){
reset();
while (!Countdown(countdown_time,962)) {
reset();
while (digitalRead(button2)==1){};
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
<#include <math.h>
int ledpin = 34;
int segA = 2;
int segB = 3;
int segC = 4;
int segD = 5;
int segF = 7;
int segG = 8;
//int segPD = ;
int button1=13;
int button2=12;
int button3=16;
int button4=17;
int digit[4];
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
case 10:
if (i == digit) {
int zeros=0;
int d;
d=n/pow(10,3-i);
zeros += d;
dig.digit[i]=d;
dig.digit[i]=10;
return dig;
return;
SwitchDigit(j);
delay(5);
PrintNumber(q,del);
return false;
PrintNumber(0,0);
return true;
void reset() {
m=countdown_time;
SwitchDigit(j);
delay(5);
pressed3 += 1;
pressed4 += 1;
pressed3=0;
pressed4=0;
void loop(){
reset();
reset();
TryingPreformatted textg to get a longer tone out of this code
Is this formatted correct
Using Arduino mega with 7 segment display
Hugely inefficient way to extract digits.
You forgot to put your code in code tags, like
code tags
Before you do that, apply auto indentation from the IDE with ctrl-T.
Please read the forum instructions, and fix your post.
Oh! Wait! You have already been asked to do that!
Did you forget to use code tags when posting ?
it looks like the tone should play for about one second (1000000 microseconds). How long is it playing? How long do you want it to play?
Right now for a second, would like to bo for about 1 minute and learn how to adjust the code.
Thank you
Guy
Yes, I am new, anything I can do to correctly post and speed up the process, can you help??
Thank you
Guy
Yes I can help. There is a very easy to use function inside the arduino-IDE to post code in the expected way. It needs only a few mouse-clicks
read this tutorial
best regards Stefan
The second argument to playTone() is the number of milliseconds to play the tone. The current value is 1000 which means one second. To get one minute (60 seconds) the value should be 60 times as high:
playTone(1519, 60000);
Got it,
Thank you very much
Yup, got it
Thank you
Another question, how to put a stop function if i wanted to use as a alarm.
Thanks
As soon as i hit ctrl-t, it sends me to a new window.
I am using cromebook
IF you want to be a successfulcode-writer you should read tutorials down to the end
There is a second method that doesn't need pressing Ctrl-T
best regards Stefan
    // If someone presses the Stop button, end the sound early
    if (digitalRead(StopButtonPin) == LOW)
Thank you,
will do that shortly.
Guy
Tried, but would not take, think i need to re name stop button pin
I changed Stop button pin to button 1, and it works.
Thank you.
I hope that I am not bothering you to much
Now I just have to add a PIR sensor and code so when i enter my home i will have 60 seconds to turn the alarm off
