Trying to get ATmega328PB to work with Arduino IDE
I have made a custom board for my class with both a PIC16F1829 and ATmega328PB-AU chips. But, having problems getting the 328PB to work. I can use a programmer with the SPI header and program the chip using Microchip Studio, but I can't get the bootloader working with the Serial connection and the Arduino IDE.
I have a 100nF connected from DTR to Reset and the fuses set as recommended by Pololu
EX, Hi , Lo =F4 DE FF and Lock initially FF then changed to CF after loading the bootloader
Very useful and complete tutorial: Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
The fuses may not be set correctly, in which case the UART baud rate will be wrong.
Use this to check: AVR Fuse Calculator for ATmega328P
Otherwise, for help you will need to provide many more details. See the "How to get the best out of this forum" post for instructions.
The MiniCore core may be useful. The MiniCore core can be used to bootload (set fuses) and program the mega328PB using the Arduino IDE.
Truthfully, you should be able to use a 328pb just like a 328p (same bootloader, etc) - there's nothing there that "needs to know" about the extra features of the PB.
Using a core like MiniCore with explicit PB support is still a good idea...
What are you using for a USB/Serial converter chip? Are you sure it's connected properly? (I've made several Arduino-like PCBs, and the most recent one connected TX to TX and RX to RX, which doesn't work. And that wasn't the first time, either.)
(Also, for example, the mEDBG on an Xplained Mini 328pb only does 56kbps...)
