trying to get delay for servo
Hi there,
I am trying to get the servo to delay for 1 second after moving for 5 seconds.
how do I modify this code to do this?
#include <Servo.h>
Servo myservo;
//set potpin to analog pin A0
int potpin = 0;
long pausetime = 1000;
int val;
  myservo.attach(9);
  long currentMillis = millis();
  long previousMillis = 0;
  long interval = 1000;
  if(currentMillis - previousMillis > interval)
    SpeedAndDirection();
void SpeedAndDirection(){
  //read value from A0(potpin)
  val = analogRead(potpin);
  //set val readings(ohms) to servo action(postion)
  val = map(val, 0, 1000, 1000, 2000);
  //using val, write position to servo
  myservo.writeMicroseconds(val);
  //Delay.
  delay(pausetime);
You have previous millis as a local variable that gets wiped every time round the loop. Make it either a static or a global variable type.
hey grumphy mike!
thank for replying me. how do i get about doing that?
Hint: "potpin" is a global.
what is "global"?
In scope everywhere.
nerdkidleo: what is "global"?
http://arduino.cc/en/Reference/scope
ok i tried previousMillis to global but its still not giving me the delay i want.
#include <Servo.h>
Servo myservo;
int potpin = 0;
int val;
  myservo.attach(9);
Well it does what you wrote, that is the SpeedAndDirection function gets called every second. So what ever is your problem it is not the delay part.
