Trying to get my OLED screen working
Just trying to figure out what I am missing for the external screen to work, it only works when I run the i2c example code.
#include <Servo.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#include <SPI.h>
#define i2c_Address 0x3c
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(128, 64, &Wire, -1);
Servo myservo;
const int SERVO_PIN = 9;
const int SERVO_HOME = 35;
const int SERVO_90 = 143;
const int SHAKE_STEP = 6;
const int TOTAL_SHAKES = 30; // Number of times to attempt to jiggle the pin free
//Set up button and valve pins
const int ROLL_SOLENOID_PIN = 10;
const int SPRING_SOLENOID_PIN = 11;
const int L_BUTTON_PIN = 7;
const int R_BUTTON_PIN = 8;
const int LED_PIN = A2;
const int PHOTORESIST_PIN = A3;
const int PRESSURE_SENSOR1_PIN = A1;
const int SENSOR2_PIN = A0;
const int BACKUP_SOLENOID_PIN = 12;
int l_buttonState = LOW; // Initial state of buttons
int r_buttonState = LOW; // Initial state of buttons
int pressure_sensorState = LOW;
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
const int RESISTOR_THRESHOLD = 250;  // analog read threshold determined via testing
int step = 1;
  // Start serial monitor
  // Attach servo obj to pin
  myservo.attach(SERVO_PIN);
  myservo.write(SERVO_HOME);
  // Set up pin modes
  pinMode(ROLL_SOLENOID_PIN, OUTPUT);
  pinMode(SPRING_SOLENOID_PIN, OUTPUT);
  pinMode(L_BUTTON_PIN, INPUT_PULLUP);
  pinMode(R_BUTTON_PIN, INPUT_PULLUP);
  pinMode(LED_PIN, OUTPUT);
  pinMode(PHOTORESIST_PIN, INPUT);
  pinMode(BACKUP_SOLENOID_PIN, OUTPUT);
  pinMode(PRESSURE_SENSOR1_PIN, INPUT);
  pinMode(SENSOR2_PIN, INPUT);
int l_buttonState = LOW; // Initial stPIN, INPUT_PULLUP);
  // Turn on the LED for the pin sensor
  digitalWrite(LED_PIN, HIGH);
void errorBlink(int error_code){
  // Blink various error patterns for different failures
  // Pull the cylinders back
  digitalWrite(SPRING_SOLENOID_PIN, LOW);
  digitalWrite(ROLL_SOLENOID_PIN, LOW);
  Serial.println("Entering error blink mode...");
  Serial.print("Error code: ");
  Serial.println(error_code);
  // Blinking 3 times in quick succession with 2 sec pause is no pin
  if (error_code == 1){
    Serial.println("Error message: Pin not dropping into place");
    while(true){
      digitalWrite(LED_PIN, LOW);
      delay(2000);
      for (int i=0; i < 3; i++){
        delay(200);
        delay(200);
  // Blinking 5 times in quick succession with 2 second pause is carriage not forward error
  if (error_code == 2){
    Serial.println("Error message: Carriage is not fully forward after 2nd check. Look for debris in lock pin");
    while(true){
      // Turn off LED
      // Hold off for 2 seconds
      delay(2000);
      // Blink 5 times
      for (int i=0; i < 5; i++){
        delay(200);
        delay(200);
void servoSerial(){
  Serial.print("Max:");
  Serial.print(180);
  Serial.print(",");
  Serial.print("Min:");
  Serial.print(0);
  Serial.print(",");
  Serial.print("Servo:");
  Serial.println(myservo.read());
  // This is microseconds
  Serial.println(myservo.readMicroseconds());
bool checkPin(){
  // Return True if the pin is in place (ie - the value is below threshold)
  // Return False if the pin is not in place yet
  // Reading is averaged over several readings defined by AVG_VALS
  // Set up some variables for smoothing photoresistor readings
  const int AVG_VALS = 5;
  int vals[AVG_VALS] = {0, 0, 0, 0, 0};
  float avg = 0;
  int total = 0;
  int reading = 0;
  for (int i = 0; i < AVG_VALS; ++i){
    reading = analogRead(PHOTORESIST_PIN);
    Serial.print("Photoresistor reading:");
    Serial.println(reading);
    vals[i] = reading;
    delay(50);
  for (int k = 0; k < AVG_VALS; k++){
    total = total + vals[k];
  avg = total/AVG_VALS;
  Serial.print("Average of photoresistor:");
  Serial.println(avg);
  if(avg < RESISTOR_THRESHOLD){
    return true;
  }else{
    return false;
bool shakePin(){
  // Move the turret in a small step to try to shake the roll pin into the turret
  // Continue to shake until the TOTAL_SHAKES is reached or until the buttons are released
  // Return true if the pin falls in place
  // Return false if the buttons are released
  // Error out and blink the LED if the max number of shakes is reached
  //Serial.println("Shaking the pin into place...");
  int shakes = 0;
  bool pinOut = true;
  bool button_check = checkButtons();
  Serial.println("Shaking the pin into place");
  while (pinOut && shakes < TOTAL_SHAKES && button_check){
    myservo.write(SERVO_HOME+SHAKE_STEP);
    delay(80);
    pinOut = !checkPin();
    shakes += 1;
  if (!button_check){
    return false;
  }else{
    if (pinOut){
      errorBlink(1);
    }else{
      Serial.println("Pin has dropped into place");
      return true;
  Serial.println("Done shaking");
void moveServo(int dest){
  // dest is the destination value 0-180
  int current = myservo.read();
  while (current != dest){
    if (dest > current){
      myservo.write(current + 2);
      Serial.println("servo below destination");
      servoSerial();
    }else{
      myservo.write(current - 2 );
      Serial.println("servo above destination");
      servoSerial();
    delay(10);
void turnTurret(bool home){
  // Turn the servo which drives the roll pin turret between vertical and horizontal
  // If home=true move back to vertical
  if (home){
    Serial.println("Moving turret back to vertical");
    moveServo(SERVO_HOME);
  else{
    Serial.println("Moving the pin from vertical to horizontal...");
    moveServo(SERVO_90);
  Serial.println("Moved turret");
int buttonRead(int pin, int lastState, bool flip=true){
  // Checks if the button reading was just intermittent or if reading has been greater than the delay time.
  int reading = LOW;
  if(flip){
    reading = !digitalRead(pin);
  }else{
    reading = digitalRead(pin);
  int value = reading;
  if (reading != lastState){
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) <= debounceDelay){
    int value = lastState;
  return value;
bool checkButtons(){
  l_buttonState = buttonRead(L_BUTTON_PIN, l_buttonState);
  r_buttonState = buttonRead(R_BUTTON_PIN, r_buttonState);
  if (l_buttonState == HIGH && r_buttonState == HIGH){
  //if (l_buttonState == HIGH)  {   // Uncomment for single button operation
    Serial.println("Both buttons are pressed!");
    return true;
  if (l_buttonState == HIGH){
    Serial.println("Only the Left Button is pressed");
    display.setTextSize(1);
    display.setTextColor(SH110X_WHITE);
    display.setCursor(0, 0);
    display.println("Only the left button is pressed");
    display.display();
  if (r_buttonState == HIGH){
    Serial.println("Only the Right Button is pressed");
    display.println("Only the Right Button is pressed");
  return false;
bool checkSensor(){
 Serial.println("Checking carriage sensor**************************");
 pressure_sensorState = buttonRead(PRESSURE_SENSOR1_PIN, pressure_sensorState, false);
Serial.print("pressure_sensorState=");
Serial.println(pressure_sensorState);
Serial.println("Done checking carriage sensor ***********************");
  if (pressure_sensorState == HIGH){
     Serial.println("carriage is forward");
     return true;
  }else{Serial.println("carriage is not forward");
  display.println("carriage is not forward");
  return false;
bool checkSensor2(){
 pressure_sensorState = buttonRead(SENSOR2_PIN, pressure_sensorState, false);
     Serial.println("stock is down");
     return true;
  }else{Serial.println("stock not down");
  display.println("stock not down");
  return false;
void displayError(char msg[32]){
  display.clearDisplay();
  display.print(F("ERROR:"));
  display.print(msg);
  display.display();
  bool pin_result = false;
  while (checkButtons()){
    Serial.print("step = ");
    Serial.println(step);
    switch (step) {
      case 1:
        // Push the spring and locking pin in
        digitalWrite(SPRING_SOLENOID_PIN, HIGH);
        Serial.println("Extending the spring piston..");
        step = 2;
      case 2:
        //check carriage
        delay(250);
       if (checkSensor() == true){
        step = 3;
       }else{
         if(checkSensor() == false){
           // Throw error
            display.println("carriage still not forward");
            display.display();
           errorBlink(2);
         }else{
           step = 3;
       Serial.println("executedcase2");
       case 3:
        //check stock
        delay(250);
       if (checkSensor2() == true){
        step = 3;
       }else{
         if(checkSensor2() == false){
           // Throw error
            display.println(F("stock still not down"));
            display.display();
           errorBlink(2);
         }else{
           step = 4;
       Serial.println("executedcase3");
      case 4:
        // Turn the servo to shake the roll pin into the turret cylinder
        pin_result = shakePin();
        if (pin_result){
          step = 5;
      case 5:
        // Turn the servo to get roll pin in line with drive pin
        turnTurret(false);
        step = 6;
      case 6:
        // Fire the backup cylinder
        digitalWrite(BACKUP_SOLENOID_PIN, HIGH);
        step = 7;
      case 7:
        // drive the roll pin into the stock
        delay(1500);
        digitalWrite(ROLL_SOLENOID_PIN, HIGH);
        Serial.println("Extending the roll pin piston...");
        step = 7;
      default:
        // wait until buttons are depressed
        delay(50);
  // This stuff happens when buttons are released
  // Retract the roll pin drive pin
  // Regtract the backup solenoid
  digitalWrite(BACKUP_SOLENOID_PIN, LOW);
  //Serial.println("Retracting the roll pin piston...");
  // Retract the latch pin drive pin
  //Serial.println("Retracting the spring piston...");
  delay(2000);
  // Check if turret was turned
  if (myservo.read() != SERVO_HOME){
    Serial.print("Servo is at ");
    // Return the turret to vertical if turned
    turnTurret(true);
  step = 1;
  delay(50);
A display.begin(); call somewhere in setup() for one thing, I would think.
Which Arduino board are you using? The Adafruit_SH110X library allocates memory for the display buffer at run-time, which adds 1024 bytes to whatever the compiler reports as dynamic memory usage.
Check this.
