Trying to get my rover to turn but it won't.
I am trying to code a Rover using PID which is meant to go straight a certain distance that you input and then it is supposed to turn. I got the Rover to go straight, but I can't get it to turn for some reason. I know that in the part:
Motor1Drive((long)-pidVal3*slope);
  Motor2Drive((long)pidVal4*slope);
this is how the motor goes forward. I also know that to make it turn you need to change the sign of one of the motor drives such as
  Motor2Drive((long)-pidVal4*slope);
i also set it into two different function: one to go forward and the other to turn. However, for some reason the code doesn't read the turn function. Please help.
/* Vriable Decleration*/
//Counters Output Pins
int counterInputs1[8] = {53,51,49,47,45,43,41,39}; // this is the standard but it can be connected differently depending on the rover.
int counterInputs2[8] = {37,35,33,31,29,27,25,23};
//Counter select Pins
int counterSEL1 = 52;
int counterSEL2 = 32;
//Counter enable pins
int counterOE1 = 50;
int counterOE2 = 30;
//Counter reset Pins
int counterRST1 = 48;
int counterRST2 = 28;
// Motor Pins
int motor1PWM = 3;
int motor1Dir = 12;
int motor2PWM = 11;
int motor2Dir = 13;
/* The counterInit() method initalizes all the pin outputs for the encoders
 * Paramters:
 *		counterInputs	Is a pointer to an array of input pin numbers for one of the HCTL2016 encoder
 *		counterSEL		Pin number for the encoder "Select" pin
 *		counterOE		Pin number for the encoder "Output Enable" pin
 *		counterRST		Pin number for the encoder "Reset" pin
void counter1Init(int *counterInputs1, int counterSEL1, int counterOE1, int counterRST1)
	pinMode(counterSEL1,OUTPUT);
	pinMode(counterOE1,OUTPUT);
	pinMode(counterRST1,OUTPUT);
	for(int i = 0; i < 8; i++)
		pinMode(counterInputs1[i],INPUT);
	// Reset the counter
        digitalWrite(counterRST1,LOW);
        digitalWrite(counterRST1,HIGH);
void counter2Init(int *counterInputs2, int counterSEL2, int counterOE2, int counterRST2)
	pinMode(counterSEL2,OUTPUT);
	pinMode(counterOE2,OUTPUT);
	pinMode(counterRST2,OUTPUT);
		pinMode(counterInputs2[i],INPUT);
        digitalWrite(counterRST2,LOW);
        digitalWrite(counterRST2,HIGH);
/* The counterRead() method reads the counts from a HCTL2016 IC which is connected
 * to the quadrature encoder and it returns the counter reading which can be transformed
 * to distance or angle.
 * parameters:
 *      - counterInput[]: an array of the outputs of the counter. the first element represents
 *        Least Significant Bit (LSB).
 *      - counterOE the number of the pin connected the counter's Enable pin.
 *      - counterSEL the number of the pin connected the counter's Select pin.
 * return: the number of counts of the counter.
void counterRead(int inputs[8], int _OE, int _SEL, int counterRST, long *counter_value)
	long value = 0;
        int readBack[16];
        bool signbit = 0;
        long counterValue;
        counterValue = *counter_value;
	//Enable the counter
	digitalWrite(_OE, LOW);
	//Select High Byte
	digitalWrite(_SEL,LOW);
        //Read High Byte from Counter
	for (int i = 8; i < 15; i++)
                value = value + (digitalRead(inputs[i-8])<<i);
                readBack[i] = digitalRead(inputs[i-8]);
        readBack[15] = digitalRead(inputs[7]);
        signbit = digitalRead(inputs[7]);
        //Select Low Byte
	digitalWrite(_SEL,HIGH);
        //Read Low Byte
	for (int i = 0; i < 8; i++)
                value = value + (digitalRead(inputs[i])<<i);
                readBack[i] = digitalRead(inputs[i]);
        if(signbit)
          value = value-32768;//why?
	counterValue += value;
        digitalWrite(_OE, HIGH);
        digitalWrite(counterRST,LOW);
        digitalWrite(counterRST,HIGH);
        *counter_value = counterValue;
/* These are the methods that drive the motor
 * Usage Instruction:
 *      - Make sure the 12V power source is connected to the rover because less
 *        power sources may burn the motor drive.
 *      - To use the putMotorValue method just copy and paste it to your sketch
 *        and provide the values you want.
 * Paramters:
 *		val is a signed 9 bit number (-256, 255) which indicates the magnitude
 *			and direction of the motor
void Motor1Drive(long val)
	val = constrain(val, -255,255);
//Serial.print("Motor Val ");
//Serial.print(val);
	if (val >= 0 )
		digitalWrite(motor1Dir,HIGH);
		analogWrite(motor1PWM, val);
		val = -val;
		analogWrite(motor1Dir,LOW);
		analogWrite(motor1PWM,val);
void Motor2Drive(long val)
	if (val >= 0 )
		digitalWrite(motor2Dir,HIGH);
		analogWrite(motor2PWM, val);
		val = -val;
		analogWrite(motor2Dir,LOW);
		analogWrite(motor2PWM,val);
/* The motorInit() method initalizes all the pin outputs for the motors
 * Paramters:
void motor1Init(int motor1PWM, int motor1Dir)
        pinMode(motor1PWM,OUTPUT);
        pinMode(motor1Dir,OUTPUT);
void motor2Init(int motor2PWM, int motor2Dir)
        pinMode(motor2PWM,OUTPUT);
        pinMode(motor2Dir,OUTPUT);
/* Differentiate() method
float dt = 0;
float aDelay = 0;
float Differentiate(float input)
  float t1 = 0;
float t2 = 0;
  float diff_out = 0;
 diff_out = input - aDelay;
 aDelay = input;
 dt = t1 - t2;
  return diff_out;
/* Integrate() method
float sum = 0;
float previousError;
float error;
float Integrate(float input)
float t1 = 0;
float t2 = 0;
sum = input + sum;
    dt = t2 - t1;
    error = error - previousError;
        return sum;
/* PID() method
float PID(float input, float kp, float ki, float kd)
	return (kp*input + ki*Integrate(input) + kd*Differentiate(input));
/* The setup() method
void setup(){
    //Initializing Arduino's pins
	counter1Init(counterInputs1, counterSEL1, counterOE1, counterRST1);
	counter2Init(counterInputs2, counterSEL2, counterOE2, counterRST2);
	motor1Init(motor1PWM,motor1Dir);
	motor2Init(motor2PWM,motor2Dir);
	//Start the Serial output
long counterValue1 = 0;
long counterValue2 = 0;
float readValue1 = 0;
float readValue2 = 0;
long pidVal1 = 0;
long pidVal2 = 0;
long pidVal3 = 0;
long pidVal4 = 0;
float u_t = 0; // u(t) = 5ft;
//float motorSlope = .5;
float u_t2 = 0;
float t1 = 0;
float t2 = 0;
long dist[4] = {27000,194616,20000,276624};
+long distR[4] = {27000,194616,20000,276624};
int index = 3;
float slope = 0.1;
 float kp1 =.64029;
  float ki1 = 0;//.062678;
  float kd1 = .069619;
  float kp2 = 1.3568;
  float ki2 = 0;//2.683;
  float kd2 = .16614 ;
void firstline()
  t1 = micros();
  u_t = dist[index];
  u_t2 = distR[index];
  counterRead(counterInputs1, counterOE1, counterSEL1, counterRST1, &counterValue1);
  counterRead(counterInputs2, counterOE2, counterSEL2, counterRST2, &counterValue2);
 //void firstline(){
  pidVal1 = (long)(PID(u_t + counterValue1, kp1, ki1, kd1));
  pidVal2 = (long)-(PID(u_t - counterValue2, kp2, ki2, kd2));
  Motor1Drive((long)-pidVal1*slope);
  Motor2Drive((long)pidVal2*slope);
 t2 = micros();
  //Serial.print("Time ");
  Serial.print(t2);
  Serial.print("\t");
  //Serial.print("PID Val ");
  Serial.print(counterValue1);
  Serial.print("\t");
  Serial.println(-
  counterValue2);
//  readValue1 = 0;
//  readValue2 = 0;
//  pidVal = 0;
//  pidVal2 = 0;
//  counterValue1 = 0;
//  counterValue2 = 0;
  void turn(){ //add delay? my part
 pidVal3 = (long)(PID(u_t2 + counterValue1, kp1, ki1, kd1));
  pidVal4 = (long)-(PID(u_t2 - counterValue2, kp2, ki2, kd2));
  // add delay? my part
  firstline();
  //delay(4000);
turn();
//delay(4000);
Snippets in isolation don't provide enough information. Is the last code section the entire sketch?
Yes, the last code is the whole sketch.
