I am just trying to make contact with my SD card. It is a 16GB that was formatted with SD Card Formatter and then inserted into an Ethernet2 w/ W5500 shield. The Serial Window just shows "SD card initialization failed" every time.
I use the following sketch....
* Arduino SD Card Tutorial Example
* by Dejan Nedelkovski, www.HowToMechatronics.com
#include <SD.h>
#include <SPI.h>
File myFile;
int pinCS = 4; // Pin 10 on Arduino Uno
pinMode(pinCS, OUTPUT);
// SD Card Initialization
if (SD.begin())
Serial.println("SD card is ready to use.");
} else
Serial.println("SD card initialization failed");
return;
// Create/Open file
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.println("Writing to file...");
// Write to file
myFile.println("Testing text 1, 2 ,3...");
myFile.close(); // close the file
Serial.println("Done.");
// if the file didn't open, print an error:
else {
Serial.println("error opening test.txt");
// Reading the file
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("Read:");
// Reading the whole file
while (myFile.available()) {
Serial.write(myFile.read());
myFile.close();
else {
// empty
