Trying to get the row number when the highest value met in an array
I am having issues with this:
I have and array that has a value in it that I want locate based on the highest value found starting from the highest row number. I need the row number to do the next action. Currently I get row 0 constantly.
the code for this section I have been working on is as follows:
for (int q = 34 ; q > -1 ; q–) { // this starts at 35 counts up to 0 for the highest urgency
if (topUrgency < MainArray[q] [2]) {
topUrgency = MainArray[q] [2]; // find highest urgency
topUrgencyRow = q;
does anyone have any idea why it is not stopping at the last highest value found but going all the way to 0
Thanks in advance
Is there a good reason to only look at the 3rd element in each row?
And, anyway, you need to show your array declaration.
boolrules:
... and the rest of the code might be helpful.
Please remember to use code tags when posting code.
As the code is currently over 100 lines without notes I will not be posting it here.
the array structure is as follows:
const byte MRow = 35;
const byte MColumn = 6;
int MainArray [MRow] [MColumn] = {0};
I have a shuffle down sequence that fills the array from another source which is working correctly.
MColumn [2] is a value that is between 0 and 8.
What I'm looking for is a way to pick the value of MainArray [2] that is the highest starting at row 34 and going up.
In other words I need it to record the row that has the highest value starting at the first on.
so if I had:
1
5
8 I want it to record this row number and not continue and give me the value of 0
1
4
5
6
OK.
Please remember to use code tags when you eventually post code.
sorry that should have read 1000 lines without the cover notes
channe:
channe:
if "it"is 'q' then "it" is going to zero because that's what the for loop says to do.
EDIT: 'q' actually goes to -1.
But you are saying that topUrgency and topUrgencyRow are not correct after the for loop ends?
How is topUrgency declared?
Did you remember to initialize topUrgency?
  topUrgencyRow = 34;
  topUrgency = MainArray[topUrgencyRow][2];
  for (int q = 33 ; q > -1 ; q--)   // this starts at 35 counts up to 0 for the highest urgency
      topUrgencyRow = q;
Since you have to examine all of the entries to determine the maximum, why count backward? Counting upward is generally easier to read:
  topUrgencyRow = 0;
  for (int q = 1 ; q < 35 ; q++)
    if  (topUrgency < MainArray[q][2])
      topUrgency = MainArray[q][2]; // found a higher urgency
      topUrgencyRow = q;
int topUrgency ;
int topUrgencyRow ;
This is done in the same location as the array is declared
The idea is to get the first occurrence of the highest value so that is why I started at 35 and worked backwards. I know it sounds strange but on paper it is what is need for this project
Yup.
Please remember to use code tags when you eventually decide to post code
channe:
That would work if your comparison was
(topUrgency <= MainArray[q][2])
but your comparison is
Your comparison works if you are starting at the beginning. If you WANT to start at the end and work backwards, change ‘<’ to ‘<=’.
AWOL:
Yup.
I think attaching code might be needed when it over 1000 lines :wink:
Yeah had tried that before as well as again now after a few other changes to no effect.
I might need to re look at this entire function again to see if there is another way of returning what I am wanting
