Hello!
I'm am running a tinkercad simulation of an arduino uno. The goal is to have several LED strips that each light up (twinkle) a single led at random. If I run the same code to all strips the the same LED lights up on each strip. If I try to break it apart it runs one strip and then the next. (Which is what is happening in the code below.) I'm sure I'm missing something basic here. Any help would be appreciated!
Thanks!
~Pinky
#define NUM_LEDS 8
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(NUM_LEDS, 5, NEO_GRB + NEO_KHZ800);
#define NUM_LEDS 8
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(NUM_LEDS, 6, NEO_GRB + NEO_KHZ800);
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
strip1.begin();
strip1.show(); // Initialize all pixels to 'off'
strip2.begin();
strip2.show(); // Initialize all pixels to 'off'
Twinkle1(0xff, 0, 0, 8, 200, true);
Twinkle2(0xff, 0, 0, 8, 200, true);
void Twinkle1(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
setAll(0,0,0);
for (int i=0; i<Count; i++) {
setPixel(random(NUM_LEDS),red,green,blue);
strip1.show();
delay(SpeedDelay);
if(OnlyOne) {
setAll(0,0,0);
void Twinkle2(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
setAll(0,0,0);
strip2.show();
delay(SpeedDelay);
if(OnlyOne) {
setAll(0,0,0);
delay(SpeedDelay);
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// NeoPixel
strip1.show();
strip2.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip1.setPixelColor(Pixel, strip1.Color(red, green, blue));
strip2.setPixelColor(Pixel, strip2.Color(red, green, blue));
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
