Trying to implement a library and keep getting this error message
I’m working on my final project for my class and I needed to install a library so I could use my DHT sensor. So I installed it and I used this tutorial to help me program it and now it won’t compile and I keep getting this error message.
"Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
In file included from C:\Users\noah-\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp:22:0:
C:\Users\noah-\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
“Show verbose output during compilation”
option enabled in File → Preferences.
here is my code too
I know it’s long :o
#include <DHT.h>         // include the temperature sensor library
#define dataPin 8         // define pin 8 as the data pin for the temperature sensor
dht DHT;
int motor = 9;            // set pin 9 as the motor pin
int button = 2;           // set pin 2 as the button pin
int photocell = A0;       // set analog pin A0 as the photocell pin
int led[7] = {3, 4, 5, 6, 7, 10, 11}; // set the 3-7 and 10-11 pins as leds
int product = 0;          // set up a counter for the products
  Serial.begin(9600);     // start the serial monitor
  pinMode(motor, OUTPUT); // set motor as an output
  pinMode(button, INPUT); // set button as an input
  pinMode(led[], OUTPUT); // set leds as outputs
  int readData = DHT.read22(dataPin); // set up an integer equal to the data pin data
  float t = DHT.temperature;  // float temperature
  float h = DHT.humidity;     // float humidity
  for (int part = 0; part < 2; part++)  // set up a for loop to manufacture two parts
    digitalWrite(motor, HIGH);          // start the conveyor
    heatTreatment();                    // heat treat the part
    OperatorInput();                    // operator pushes button that operates a machine that works on the part
    Painting();                         // paint the part
    digitalWrite(motor, LOW);           // stop when the part is at the end of the other conveyor so it can wait for the second part
    Serial.println("I recieved");       // print how many parts are at the end and are waiting on another
    Serial.print(part);
    Serial.print(" amount of parts");
    digitalWrite(led[7], HIGH);         // turn on the 4th red led to indicate that a part is waiting for its other half to come before continuing
    if (part = 2)
      product++;
      digitalWrite(motor, HIGH);        // when the two parts are together on the warehouse conveyor start the warehouse conveyor motor
      Serial.print("I recieved");
      Serial.print(product);
      Serial.print(" amount of products");
      digitalWrite(led[7], LOW);        // turn off the 4th red led to indicate that the two parts were merged into one product and moved to the warehouse
void heatTreatment()
  digitalWrite(motor, LOW);     // turn off the conveyor when the part arives
  digitalWrite(led[1], HIGH);   // turn on the 1st red led to indicate that the first process has recieved the part
  Serial.print("Temperature = ");
  Serial.print(t);              // print Temperature = *C in the serial monitor
  Serial.print("*C");
  delay(2000);
  Serial.println("heat treatment complete");      // indicate that the heat treatment is complete
  digitalWrite(led[1], LOW);                      // turn off the 1st red led
  digitalWrite(led[2], HIGH);                     // turn on the 1st green led
  digitalWrite(motor, HIGH);                      // turn the conveyor back on and move part to next process
void OperatorInput()
  digitalWrite(motor, LOW);             // turn off the conveyor when the part arrives
  digitalWrite(led[3], HIGH);           // turn on the 2nd red led to indicate that the operator recieved the part
  int buttonState = digitalRead(button); // set an integer = to the buttonstate (pressed or not pressed)
  if (buttonState = HIGH)
    delay(1000);      // ghetto debounce
    Serial.println("OPERATION IN PROGRESS");  // print that the operation is in progress
    delay(2000);                              // wait two seconds
    Serial.println("OPERATION COMPLETE");     // print that the operation is complete
    digitalWrite(led[3], LOW);                // turn the 2nd red led off
    digitalWrite(led[4], HIGH);               // turn the 2nd green led on to indicate that this process is complete
void Painting()
  int analogValue = analogRead(A0);   // set an integer equal to the analog value of the photocell
  digitalWrite(led[5], HIGH); // turn on the 3rd red led to indicate that the painting process has recieved the part
  if (analogValue < 100)
    Serial.println("Painting HAS BEGUN");   // if the light value is less that 100 print that the painting process has begun
    Serial.println("PAINTING HAS FINISHED");  // print that the painting process has finished
    digitalWrite(led[5], LOW);              // turn off the 3rd red led
    digitalWrite(led[6], HIGH);             // turn on the 3rd green led to indicate that the last process has completed
Error messages don't get any more straight forward than that. Have you got that file? Where is it on your machine?
Okay i checked for any libraries i was missing and downloaded the one i needed for my sensor and im still getting the same error message
Build options changed, rebuilding all
exit status 1
#include <DHT.h>
#include <DHT_U.h>
dht DHT;
    Serial.print(part);
    if (part = 2)
      product++;
  Serial.print("*C");
  delay(2000);
void Painting()
Delta_G:
Okay i got that library now and now im getting a different message
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\noah-\Documents\Arduino\sketch_jun11a\sketch_jun11a.ino: In function 'void loop()':
sketch_jun11a:25: error: expected primary-expression before '.' token
sketch_jun11a:26: error: expected primary-expression before '.' token
C:\Users\noah-\Documents\Arduino\sketch_jun11a\sketch_jun11a.ino: In function 'void heatTreatment()':
sketch_jun11a:55: error: 't' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
Hello, I'm not a good programmer but can you try this putting the float t line in your function like below.
  Serial.print("*C");
  delay(2000);
Nevermind i got it to work with a little more tinkering thanks for the help guys
NC_Mechatronics:
Don't be rude. Someone else might have a similar problem. Show the solution too. This exercise wasn't just all about you.
