Trying to install drivers, don't know how.
I've done some searching around and have found other people asking basically this same question, but the solutions either don't seem to work for me or I'm not sure I understand the instructions. When I go to upload anything, it seems to go through ten cycles, displaying an error message saying how "programmer is not responding." Based off what I've gathered, I'm assuming this has some issue to do with the drivers. I'm brand new to all of this, and would really appreciate any help. For context, Im using a "MEGA 2560 R3" on a Mac, 10.14.4.
These steps may also save you some unnecessary time and effort in the forum.
See the drivers link if it is a clone and not a TRUE arduino.
  • Always provide as much detail as possible to your issue it may be important.
  • If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
  • If applicable provide a schematic even if hand drawn.
  • Pictures are an invaluable aid. See THIS TOPIC for help posting them.
    COMMON ISSUES
  • Check you have a COMMON GROUND where required.
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check your wiring first.
  • Remove any items connected to pins 0 and 1.
    COMPUTER RELATED
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • If using CREATE then try and INCOGNITO window or similar to rule out browser add-on's.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE's as ADMINISTRATOR or your OS equivalent
  • If you have tried multiple IDE's then you may need to perform additional clean up.
    Performing the above actions may help resolve your problem without further help.
