trying to interface with an SD card device with bizarre results
Hi
I have purchased sd card reader/writer and I'm currently trying to interface with it using the recommended library. I have an SD card installed. At the moment, I'm just trying to connect to the device to ensure that everything is working ok.
When I try the cardinfo example with chipSelect = 10 (which the documentation says is the correct chip select pin to use), the interface returns a failure:
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
int chipSelect = 10;
  delay (2000);
      Serial.print("\nInitializing SD card. Trying Chip Select ");
      Serial.println(chipSelect);
      if (!card.init(SPI_HALF_SPEED, chipSelect))
        Serial.println("initialization failed.");
        Serial.println("Wiring is correct and a card is present.");
This produces the following output:
Initializing SD card. Trying Chip Select 10
Just to make sure that I wasn't using the incorrect chipSelect pin I thought I would loop through each pin:
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
int chipSelect = 0;
  delay (2000);
  while (true)
      chipSelect++;
and to my suprise the output was as follows:
Initializing SD card. Trying Chip Select 0
Initializing SD card. Trying Chip Select 2
Initializing SD card. Trying Chip Select 3
Initializing SD card. Trying Chip Select 4
Initializing SD card. Trying Chip Select 5
Initializing SD card. Trying Chip Select 6
Initializing SD card. Trying Chip Select 7
Initializing SD card. Trying Chip Select 8
Initializing SD card. Trying Chip Select 9
Clearly chipSelect = 10 is succeeding when looping through...but not when I hardcode the chipSelect = 10. What am I missing here!?
EDIT: I have also added 'pinMode(chipSelect, OUTPUT)' and 'digitalWrite(chipSelect, HIGH)' which others have recommended but unfortunately it is still not working.
Thanks
That is indeed bizarre. I don't know anything about that module, but would suggest you try a loop trying pin 10 repeatedly until it's successful, and see how many tries it takes. The other thing would be adding a longer delay ahead of trying it the first time to see if that alone will make it work. You would think 2 seconds is already plenty, but it might be worth a try.
You may have to ask in the Adafruit forums.
ShermanP:
Thanks, they got it solved.
For anyone who comes across this issue, if you are using the M0 RFM95 Feather Module with the Featherwing Adalogger, make sure you set pin 8 to high before you interface with the SD card.
