trying to log data after RF 433mhz receiver
I've setup one arduino to read Humidity Temereatue and Frequency of sound. I have this data sent to receiving arduino that reads and shows in serial monitor.
Here is the code for the receiver:
// Include RadioHead Amplitude Shift Keying Library
#include <RH_ASK.h>
#include <SPI.h>
// Define output strings
String str_humid;
String str_temp;
String str_freq;
String str_out;
// Create Amplitude Shift Keying Object
RH_ASK rf_driver;
{ // Initialize ASK Object
 rf_driver.init();
 // Setup Serial Monitor
{ // Set buffer to size of expected message  (note: see Ask_receiverTest to make this variable.
 //uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
 uint8_t buf[17];
   uint8_t buflen = sizeof(buf);
 // Check if received packet is correct size
 if (rf_driver.recv(buf, &buflen))
 { // Message received with valid checksum
   // Get values from string
   // Convert received data into string
   str_out = String((char*)buf);
   // The entire message is in the String str_out
   // Split string into three values
   // First, find the offsets of the two commas
   int comma1 = str_out.indexOf(",");
   int comma2 = str_out.indexOf(",", comma1+1);
   // Then extract the substrings
   str_humid = str_out.substring(0, comma1);         // before first comma
   str_temp = str_out.substring(comma1+1, comma2);  // between the two commas
   str_freq = str_out.substring(comma2+1);          // after the second comma
   // Print values to Serial Monitor
   Serial.print("Humidity: ");
   Serial.print(str_humid);
   Serial.print("  - Temp: ");
   Serial.print(str_temp);
    Serial.print(" - Frequency: ");
    Serial.println(str_freq);
I want to log the data on the data logging shield V1.0, Ive tried to combine the both codes but I'm not getting any transmittion from the receiving arduino when I add the data logging elements to it
here is the code that Ive combined with my receiver code:
#include <RH_ASK.h>
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10;
String str_humid;
String str_temp;
String str_freq;
String str_out;
RH_ASK rf_driver;
{ {// Initialize ASK Object
 rf_driver.init();
 Serial.begin(9600); }
 Serial.print("Initializing SD card...");
 // see if the card is present and can be initialized:
 if (!SD.begin(chipSelect)) {
   Serial.println("Card failed, or not present");
   // don't do anything more:
   while (1);
 Serial.println("card initialized.");
 uint8_t buf[17];
 File dataFile = SD.open("datalog.txt", FILE_WRITE);
 // if the file is available, write to it:
 if (dataFile) {
   dataFile.println(str_humid);
   dataFile.println(str_temp);
   dataFile.println(str_freq);
   dataFile.println(str_out);
   dataFile.close();
   // print to the serial port too:
   Serial.println(str_humid);
   Serial.println(str_temp);
 // if the file isn't open, pop up an error:
 else {
   Serial.println("error opening datalog.txt");
I know that my coding isnt up to standard, so I need a little help in the right direction
Thank you
Please edit your post to add code tags ("</>" button on post editor).
If you are using an AVR-based Arduino (Uno, Nano, etc.) don't use Strings. They cause memory problems and unpredictable crashes.
