Trying to log GPS data in a microSD card
Hello all
Im using an arduinoBT, a Parallax GPS module and the libelium microSD module from the playground with TinyGPS and Filelogger libraries in order to log my GPS data to the microSD card.
I can print GPS data using the TinyGPS lib to the serial monitor and save strings to my microSD using the Filelogger lib (2 different scetches)
I wrote a combined program to save my GPS data in the SD card, its compiles but it doesnt seem to work. Heres my code:
#include <NewSoftSerial.h>
#include <TinyGPS.h>
#include <FileLogger.h>
#define MEM_PW 8
#define MESSAGE "Lat/Long(10^-5 deg): "
#define COMMA  ","
#define ENDL "\n"
unsigned long length = sizeof(MESSAGE)-1;
byte buffer1[] = MESSAGE;
byte buffer2[10];
byte buffer3[] = COMMA;
byte buffer4[] = ENDL;
void prinMSG(int);
NewSoftSerial nss(2,3);
TinyGPS gps;
bool feedgps();
long latitude,longitude;
unsigned long age;
int result=0;
nss.begin(4800);
Serial.println(" Testing :...");
    result = FileLogger::append("data.txt", buffer1, length);
    prinMSG(result);
    feedgps();
    gps.get_position(&latitude, &longitude, &age);
    buffer2[0]=latitude;
    result = FileLogger::append("data.txt", buffer2, 7);
    prinMSG(result);
    result = FileLogger::append("data.txt", buffer3, 1);
    prinMSG(result);
    buffer2[0]=longitude;
    prinMSG(result);
    result = FileLogger::append("data.txt", buffer4, 1);
    prinMSG(result);
    delay(2000);
bool feedgps()
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
void prinMSG(int result)
Serial.print(" Result: ");
        if( result == 0)
          Serial.println("OK");
        else if( result == 1)
          Serial.println("Fail initializing");
        else if( result == 2)
          Serial.println("Fail appending");
The program is supposed to print a confirmation message on the serial monitor everytime it saves the longtitude and latitude in the SD card, but i get nothing in the txt file that has been previously saved in the SD neither in the serial monitor. Not even the “Testing :…” message included in void setup ().
any thoughts?
for the record, I have my microSD shield connected on the digital pins. Come on guys, need some advice before I try other libraries..
Possible known issue http://code.google.com/p/arduino-filelogger/issues/list
Regards
Chewie Baker
