Hello. I am trying to compare two different images with my Arduino. I have found some code that is really good and I am pretty sure it is only possible to do exactly this way with .net framework but the idea is very good and I am trying to figure out how I can do this with Arduino. Here is a link to the code.
Hope someone has some tips and hope you enjoy the article thanks.
// Lock the bitmap's bits.
Rectangle rect = new Rectangle(0, 0, bmp.Width, bmp.Height);
BitmapData bmpData = bmp.LockBits(rect, ImageLockMode.ReadWrite, PixelFormat.Format24bppRgb);
// Get the address of the first line.
IntPtr ptr = bmpData.Scan0;
// Declare an array to hold the bytes of the bitmap.
int bytes = bmpData.Stride * bmp.Height
I don't know how to replace lock bmp.lockbits or stride
The Bitmap class with all of these comes from .Net framework. Does anyone know similar classes?
Use Google to discover what lockbits means in c#. First return told me you can ignore it for an Arduino. You can do similar searches when you find a phrase you don't understand.
Paul
This article shows me how to take a byte array from a jpg and turn it into a hex string. This is the answer to my question. Sorry to ask people to do my work for me. That should do I hope. Hope it helps someone one day.
