Hi! Wonder if anyone could help me out here with this code because I keep getting several problems. Whenever I try to upload my code, I get an error message saying 'exit status 1 expected unqualified-id before 'if''
Here's my code:
int val = 0;
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
digitalWrite(9,HIGH);
digitalWrite(8,LOW);
digitalWrite(13,HIGH);
digitalWrite(12,LOW);
if(analogRead(A0) > 500) // This is the Left Sensor
digitalWrite(8,LOW); // Stops the Right motor from moving
digitalWrite(9,LOW);
digitalWrite(9,HIGH); // Makes the Right motor move foward
end
if(analogRead(A3) > 500) // This is the Right Sensor
digitalWrite(13,LOW); // Stops the Left Motor from moving
digitalWrite(13,HIGH); // This makes the Left motor move foward.
Serial.println(val); // Prints the Sensor Value
int val = 0;
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
} //DELETE THIS - this closes the loop() function, so all the code after it is not in a function, which is not valid
end
Thanks for that it worked but the second part of the analogRead is still having troubles. Im doing the same way you told me to do it but now the '}' is having problems at the end, I delete the last last one. I delete it and it says it has problems. I put it back. It says "expected '}' at end of input" and if I delete it this is what it says the same thing.
Ok so a friend helped me out and the code works now!
But there is one problem. The wheels wont move and if I try printing the serial so I can see, it's stuck at the number '243' and it wont go up or down.
But the main problem is the sensors work but the wheels don't move one pixel.
