Trying To make 4ch IR relay using attiny85
Hiii Guys …
i am trying to make 4ch ir controlled relay for my home using ATTINY 85
using the following Code
#include <IRremote.h>
#include <TinyWireM.h>
int receiver = 1;
int relay = 3;
IRrecv irrecv(receiver);
decode_results results;
  pinMode(receiver, INPUT);
  pinMode(relay, OUTPUT);
  irrecv.enableIRIn();
int on = 0;
unsigned long last = millis();
void loop()   {
  if (irrecv.decode(&results))
    on = !on;
    translateIR();
    irrecv.resume();
void translateIR()
  switch(results.value)
  case 0xE0E020DF: digitalWrite(relay, on ? HIGH : LOW);
after i hit compile it says error compiling for board attiny 85…
/root/Arduino/libraries/IRremote/IRremoteInt.h:253:16: error: ‘CS20’ was not declared in this scope
** TCCR2B = _BV(CS20); **
/root/Arduino/libraries/IRremote/IRremote.cpp:306:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL’
** TIMER_CONFIG_NORMAL();**
In file included from /root/Arduino/libraries/IRremote/IRremote.cpp:21:0:
Multiple libraries were found for "TinyWireM.h"
** Used: /root/Arduino/libraries/TinyWireM**
Multiple libraries were found for "IRremote.h"
** Used: /root/Arduino/libraries/IRremote**
/root/Arduino/libraries/IRremote/IRremoteInt.h:254:3: error: ‘OCR2A’ was not declared in this scope
** OCR2A = TIMER_COUNT_TOP; **
/root/Arduino/libraries/IRremote/IRremoteInt.h:255:3: error: ‘TCNT2’ was not declared in this scope
** TCNT2 = 0; **
/root/Arduino/libraries/IRremote/IRremoteInt.h:239:31: error: ‘TIMSK2’ was not declared in this scope
** #define TIMER_ENABLE_INTR (TIMSK2 = _BV(OCIE2A))**
/root/Arduino/libraries/IRremote/IRremote.cpp:309:3: note: in expansion of macro 'TIMER_ENABLE_INTR’
** TIMER_ENABLE_INTR;**
In file included from /root/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/avr/include/avr/io.h:99:0,
** from /root/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/avr/include/avr/pgmspace.h:90,**
** from /root/.arduino15/packages/diy_attiny/hardware/avr/2018.9.9/cores/tiny/Arduino.h:9,**
** from /root/Arduino/libraries/IRremote/IRremoteInt.h:20,**
** from /root/Arduino/libraries/IRremote/IRremote.cpp:21:**
/root/Arduino/libraries/IRremote/IRremoteInt.h:239:44: error: ‘OCIE2A’ was not declared in this scope
Using library IRremote in folder: /root/Arduino/libraries/IRremote (legacy)
Using library TinyWireM at version 1.1.0 in folder: /root/Arduino/libraries/TinyWireM
exit status 1
Error compiling for board ATtiny85.
getting this error
Does the IRremote library support the ATtiny85? Those errors happen because they refer to processor timer hardware that is different on the ATtiny. If I had this problem, I would be running to the library documentation.
