Trying to make a glove with flex sensors that controls keyboard inputs on my pc
I am attempting to use an arduino leonardo to send keyboard inputs for gaming. For example, when I bend one of the flex sensors more than a certain limit, the arduino then uses the "Keyboard.press('w')" command to send the letter 'w' as an input. this has worked perfectly for 1 sensor, but when I try to read 2 at once, it doesn't recognize the second one and does nothing.
this is the code that i used
#include <Keyboard.h>
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  Keyboard.begin();
  while (analogRead(A0) < 150){
    Keyboard.press('w');
    delay(10);
  while (analogRead(A0) > 150) {
    Keyboard.release('w');
  while (analogRead(A1) < 150) {
    Keyboard.press('e');
    delay(10);
  while (analogRead(A1) > 150) {
    Keyboard.release('e');
I then found out that you can not use both inputs at the same time and that they have to be delayed in order for it to read only one pin at a time, so my final question is: how do i implement this delay in the code?
you are using while loops
    delay(10);
you will be stuck forever in the above loop while A0 < 150
similar with the other loops
try reading the analogue inputs and using if statements, e.g. along the lines of
  int a0=analogRead(A0);
  if (a0 < 150){
    delay(10);
 else {
similar for A1
so what loop should i use?
i see, i will try that
it has worked perfectly, thank you for the reply!
