Hello,
So i am currently working on a project that requires constantly sending data to thingspeak server using GSM. I recently started learning how GSM (SIM808) works and i have followed basic tutorials and codes to send data to thingspeak server using GSM but i have noticed that i has a too many delays and with my past experience i can say that using delays messes with rest of the program execution. And in my code there is a lot of PID motor control and other calculations so i am trying to make a code without delays. I know about millis() but i don't exactly know how to use it efficiently. So here's the code.
#define GSM Serial2
int seq, seq_comp = 0;
String ack, dummy ;
int x,y,z = 0;
void ShowSerialData()
// while (GSM.available() != 0)
// Serial.write(GSM.read());
// while (Serial.available() != 0)
// GSM.print(Serial.read());
// delay(10);
Serial.println(seq);
Serial.print(" ");
// Serial.println(ack);
GSM.begin(9600);
if (seq == 0)
GSM.println("AT");
ack = GSM.read();
ShowSerialData();
if (ack == "OK")
seq++;
ack = dummy;
else if (seq == 1)
GSM.println("AT+CPIN?");
ack = GSM.read();
ShowSerialData();
if (ack == "ERROR")
seq = 1;
ack = dummy;
seq++;
ack = dummy;
else if (seq == 2)
GSM.println("AT+CREG?");
ack = GSM.read();
ShowSerialData();
if (ack == "ERROR")
seq = 2;
ack = dummy;
seq++;
ack = dummy;
else if (seq == 3)
GSM.println("AT+CGATT?");
ack = GSM.read();
if (ack == "ERROR")
seq = 3;
ack = dummy;
seq++;
ack = dummy;
else if (seq == 4)
GSM.println("AT+CIPSHUT");
ack = GSM.read();
ShowSerialData();
if (ack == "SHUT OK")
seq++;
ack = dummy;
else if (seq == 5)
GSM.println("AT+CIPSTATUS");
ack = GSM.read();
ShowSerialData();
if (ack == "OK")
seq++;
ack = dummy;
else if (seq == 6)
GSM.println("AT+CIPMUX=0");
ack = GSM.read();
ShowSerialData();
if (ack == "OK")
seq++;
ack = dummy;
else if (seq == 7)
GSM.println("AT+CSTT=\"airtelgprs.com\"");
ack = GSM.read();
ShowSerialData();
if (ack == "OK")
seq++;
ack = dummy;
else if (seq == 8)
GSM.println("AT+CIICR");
ack = GSM.read();
ShowSerialData();
if (ack == "OK") // Wireless connection
seq++;
ack = dummy;
else if (seq == 9)
GSM.println("AT+CIFSR"); // change ACK
ack = GSM.read();
ShowSerialData();
if (ack == "ERROR")
seq = 9;
ack = dummy;
seq++;
ack = dummy;
else if (seq == 10)
GSM.println("AT+CIPSPRT=0");
ack = GSM.read();
ShowSerialData();
if (ack == "OK")
seq++;
ack = dummy;
else if (seq == 11)
GSM.println("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\""); // change ack
ack = GSM.read();
ShowSerialData();
if (ack == "ERROR")
seq = 11;
ack = dummy;
seq++;
ack = dummy;
else if (seq == 12)
GSM.println("AT+CIPSEND");
String str = "GET https://api.thingspeak.com/update?api_key=Z5W13HEYV8ZRTZNI&field1=" + String(x) + "&field2=" + String(y) + "&field3=" + String(z);
GSM.println(str);
ack = GSM.read();
ShowSerialData();
if (ack == "SEND OK")
seq++;
ack = dummy;
else if (seq == 13)
GSM.println((char)26);
ack = GSM.read();
ShowSerialData();
if (ack > 0)
seq++;
ack = dummy;
else if (seq == 14)
ack = GSM.read();
ShowSerialData();
seq++;
ack = dummy;
The code is pretty simple if the "AT" command returns "OK" then it would move to the next AT command, if returns an error then that AT command is repeated. Some of the commands don't return "OK", they return some other values or modes selected, so in that case i set the condition if the acknowledgment is "ERROR" then the sequence number remains the same, else go to the next sequence. The way i verify the acknowledgment is that after sending the AT command i read the acknowledgment by saving it in a string variable "ack" and then compare it with the string, if identical then move to the next command and clear the "ack" variable. I have not worked with "Strings" before so i don't exactly know how they work in conditional statements. Now the problem in this code is that it won't move past the first sequence so something is wrong in the conditional statement but i don't know what?
