trying to make a LED passcode using the letters 'abc' in all different ways HELP
for (int thisPin = 2; thisPin < 7; thisPin++) {
pinMode(thisPin, OUTPUT);
if (Serial.available() > 0) {
int inByte = Serial.read();
switch (inByte) {
case “abc”:
digitalWrite(2,HIGH);
digitalWrite(2,LOW);
case"acb"
digitalWrite(3, HIGH);
digitalWrite(3, LOW);
case"bac"
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
case “bca”:
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
case “cab”:
digitalWrite(6, HIGH);
digitalWrite(6, LOW);
default:
digitalWrite(thisPin, LOW);
ERROR
sketch_jan20a:14: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
case “abc”:
sketch_jan20a:14: error: conversion from pointer type ‘const char (*)[4]’ to arithmetic type ‘int’ in a constant-expression
sketch_jan20a:19: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
case"acb"
sketch_jan20a:19: error: conversion from pointer type ‘const char (*)[4]’ to arithmetic type ‘int’ in a constant-expression
sketch_jan20a:20: error: expected ‘:’ before ‘digitalWrite’
sketch_jan20a:24: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
case"bac"
sketch_jan20a:24: error: conversion from pointer type ‘const char (*)[4]’ to arithmetic type ‘int’ in a constant-expression
sketch_jan20a:25: error: expected ‘:’ before ‘digitalWrite’
sketch_jan20a:29: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
case “bca”:
sketch_jan20a:29: error: conversion from pointer type ‘const char (*)[4]’ to arithmetic type ‘int’ in a constant-expression
sketch_jan20a:34: error: invalid conversion from ‘const char*’ to ‘int’ [-fpermissive]
case “cab”:
sketch_jan20a:34: error: conversion from pointer type ‘const char (*)[4]’ to arithmetic type ‘int’ in a constant-expression
exit status 1
  switch (inByte) {
    case "abc":[
Input a byte, compare (sort-of) to a string. See the problem?
Please use code tags when posting code.
expanding AWOL's comments:
if (Serial.available() > 0) { int inByte = Serial.read();
switch (inByte) { case "abc":
you take in a SINGLE byte and compare it against a string literal...
read about the Serial Input Basics
To add to what's above, C++ doesn't allow switch case on strings. Only integer types can be used, like byte, char, int, long etc. So even if you read the data in correctly, you can't use a switch case with it. You'll have to use a cascaded set of if statements.
So how would the code be written. Like i said sorry guys im very new an its just alot soo yea.
Start with "strcmp"
BTW
case"bac" <<<<<<<< if this was right, it would need a : at the end of the line.
switch (inByte){
case “abc”:
case"acb":
case"bac":
case “bca”:
case “cab”:
default:
Well, we've got the problem that a single character is never going to equal a string. So, you need to input a sequence of characters and form them into a string, then use strcmp, as mentioned above, and get rid of the switch/case, also as mentioned above.
There's a sticky thread called Serial Basics, which you should read.
And we have the problem that you've missed out the code tags.
Could you right it down how i should be looking like ? Like copy an edit it then paste it if you could please so it would help me while i am reading the other basics on it
Sure - here
Well whats a code that is easier or simpler to do just to make a 3 number or letter password thats all im trying to do an i have been readinng that an its not really helping like i see what its saying but im still stuck so…yea any other ideas on thing i could do all im wanting to do is make a passcode with LEDS making it to where the right combination will turn a Green LED on an the rest will be red thats all so yea any help i would surely appreciate
You will have to face the fact that you have to work yourself, at least you should try to.
