Please don't judge, but I'm kinda new to coding in Arduino and to this forum
pretty much, I've been trying to create a menu which uses a 16x2 LCD with an analog joystick and a buzzer.
everything works except, whenever i move the joystick, nothing happens, it does make the scrolling click sound but the menu variable (M) doesn't change.
here's my code (don't mind the huge setup part, it's a little startup animation that i created)
#include <LiquidCrystal.h>
//integer setup
const int BL = 9; //backlight pin
const int C = 6; //contrast pin
const int Sw = 13; //joystick switch pin
int S = 0; //joystick switch state
const int Ml = 1023; //joystick max limit
const int B = 10; //buzzer pin
int M = 0; //menu choice
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 lcd.begin(16, 2);
 //pin setup
 pinMode(BL, OUTPUT);
 pinMode(S, INPUT);
 pinMode(C, OUTPUT);
 //startup animation
 analogWrite(C, 120);
 analogWrite(BL, 0);
 lcd.clear();
 lcd.print("-                           -");
 delay(25);
 analogWrite(BL, 20);
 lcd.clear();
 lcd.print("--                          --");
 delay(25);
 analogWrite(BL, 40);
 lcd.clear();
 lcd.print("---                         ---");
 delay(25);
 analogWrite(BL, 60);
 lcd.clear();
 lcd.print("----                        ----");
 delay(25);
 analogWrite(BL, 80);
 lcd.clear();
 lcd.print("-----                       -----");
 delay(25);
 analogWrite(BL, 100);
 lcd.clear();
 lcd.print("------                      ------");
 delay(25);
 analogWrite(BL, 120);
 lcd.clear();
 lcd.print("-------                     -------");
 delay(25);
 analogWrite(BL, 140);
 lcd.clear();
 lcd.print("--------                    --------");
 delay(25);
 analogWrite(BL, 160);
 lcd.clear();
 lcd.print("---------                   ---------");
 delay(25);
 analogWrite(BL, 180);
 lcd.clear();
 lcd.print("----------                  ----------");
 delay(25);
 analogWrite(BL, 200);
 lcd.clear();
 lcd.print("-----------                 -----------");
 delay(25);
 lcd.clear();
 lcd.print("------------                ------------");
 delay(25);
 lcd.clear();
 lcd.print("-------------               -------------");
 delay(25);
 lcd.clear();
 lcd.print("--------------              --------------");
 delay(25);
 lcd.clear();
 lcd.print("---------------             ---------------");
 delay(25);
 lcd.clear();
 lcd.print("----------------            ----------------");
 delay(250);
 tone(B, 1000);
 delay(100);
 tone(B, 900);
 delay(100);
 tone(B, 1000);
 delay(100);
 tone(B, 1100);
 delay(100);
 tone(B, 1500, 100);
 lcd.clear();
 S = digitalRead(Sw); //switch state setup
 //refresh
 delay(50);
 lcd.clear();
Â
Â
 //display menu
 if (M == 0) {
  lcd.print(">Brightness              -Contrast");
 if (M == 1) {
  lcd.print(">Contrast");
Â
 if (M == 2) int M = 1; //maximum menu choice
 if (M == -1) int M = 0; //minimum menu choice
 //if joystick goes up
 if (analogRead(A0) == Ml){
  M = (M-1);
  tone(B, 2000, 2);
  delay(100);
Â
 //if joystick goes down
 if (analogRead(A0) == 0){
  M = (M+1);
  tone(B, 1500, 2);
  delay(100);
 //if button is clicked
 if (S == LOW){
  tone(B, 2000);
  delay(10);
  tone(B, 1500, 10);
  delay(100);
help would be appreciated
