trying to make a motor run by using the case function
Hi. Im currently trying to make a motor run by using the case function for a BB8 project im doing.
I have checked all the parts of the code and made them run separately. But when I put it together it seems that it completely over looks the part of the code that makes the motor run. If anyone could help my out that would be lovely.
[code]
#include <AFMotor.h>
AF_DCMotor motor1(3, MOTOR12_64KHZ);
AF_DCMotor motor2(4, MOTOR12_64KHZ);
char command;
  if (Serial.available() > 0) {
    command = Serial.read();
    switch (command) {
      case 'F':
        motor1.setSpeed(200);
        motor1.run(BACKWARD);
        motor2.setSpeed(200);
        motor2.run(FORWARD);
      case 'B':
        motor1.run(FORWARD);
        motor2.run(BACKWARD);
      case 'L':
        motor2.setSpeed(100);
      case 'R':
        motor1.setSpeed(100);
      default:
        motor1.setSpeed(0);
        motor2.run(RELEASE);
        motor2.setSpeed(0);
[/code]
Add Serial.write(command); so you can see what the Arduino actually receives.
...R
It just spits out a lot of nothing when i do so. Do you have an idea of what might be the problem?
ali_manice:
If there is a lot of it then it can't be nothing.
Please post the latest version of your program and a sample of the output.
...R
the code
[code]
char command;
    switch (command) {
      case 'F':
      case 'B':
      case 'L':
      case 'R':
      default:
        motor1.setSpeed(0);
        motor2.setSpeed(0);
[/code]
and seriel output
FF
It's rather pointless trying to send the command to the Serial Monitor before it has been received.
Change this
to this
...R
