Project info: I am trying to make an alarm clock that turns on my coffee maker. I would like to use the atmega328's internal clock instead of an RTC. I will eventually integrate an lcd and the relay and make it standalone, but I am fairly new to arduino so I am taking baby steps.
No errors in compiling or uploading to my UNO board, but the alarmisON function seems to always be true. What am I doing wrong?
//defines
long day = 86460000; // 86400 sec/day adjusted for the atmega328 clock
long hour = 3602500; // 3600 sec/hour " "
long minute = 60041; // 60 sec/min " "
long second = 1000; // 1000 millis/sec, unadjusted
long alarmTime = 60041;
//setup
void setup(){
Serial.begin (9600);
millis() == 0;
//todo: add a caseopened function to detect if the system has been loaded since it last went off. If it hasn't been loaded, set the alarm to not go off
void loop(){
time();
if(millis() >= 86460000 ){ //resets the mils counter at "midnight"
millis() == 0;
void time(){
long timeNow = millis();
int days = timeNow / day ; //days since reset
int hours = (timeNow % day) / hour; //hours since start of day
int minutes = ((timeNow % day) % hour) / minute ; //minutes since start of hour
int seconds = (((timeNow % day) % hour) % minute) / second; //seconds since start of minute
//turning the alarm on
if (alarmTime = timeNow){
boolean alarmisON = true;
else{
boolean alarmisON = false;
// display current time
Serial.print(hours);
printDigits(minutes);
printDigits(seconds);
if (boolean alarmisON = true){
Serial.print(" boolean alarmisON = true");
else {
Serial.print(" boolean alarmisON = false");
//pretty stuff
void printDigits(byte digits){
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits,DEC);
delay (1);
This doesn't do anything, == is for making comparisons
millis() == 0;
millis() returns a value - don't believe you can set it with millis() = 0;
make these unsigned long and put UL after the number.
make any variables having to do with millis() unsigned long
this needs == for comparison
otherwise you are setting alarmTime equal to timeNow, which apparantly equates to being True within the if()
Some small corrections (as noted above by 'CrossRoads')
const unsigned long second = 1000UL;
const unsigned long minute = 60UL * second;
const unsigned long hour = 60UL * minute;
const unsigned long day = 24UL * hour;
const unsigned long alarmTime = 60041UL;
millis() == 0;
time();
void time()
unsigned long timeNow = millis();
int days = timeNow / day; // days since reset
int hours = (timeNow % day) / hour; // hours since start of day
int minutes = ((timeNow % day) % hour) / minute; // minutes since start of hour
bool alarmisON = ((alarmTime == timeNow) ? true : false);
Serial.print(" boolean alarmisON = ");
Serial.println((alarmisON ? "true" : "false"));
Serial.print(":");
if ( digits < 10 )
Serial.print('0');
Serial.print(digits, DEC);
delay(1);
You don't control the value of millis(). That's a "system" thing. If you want to turn on the coffee machine at a specified wall clock time, you have to use an RTC, otherwise whenever the arduino is reset millis() will restart from zero.
Oh, and please take away that delay(1) inside printDigits()
