Trying to make an ir translator using Case and Switch but no go
Hello, Y’m trying to make an ir translator base on some sketch that y have seen but y’m having problem detecting the code that will triggers the correct SendRaw , my remote is a Samsung , it is a RAW code string that y have to work whit, the example y have seen are made with HEX code so can y make this work with Raw code using the Case and Switch convention
in my design i want " raw_muteTV to be the trigger to send raw_muteSB, i know my raw codes are good because i tested the code with the simple sendRaw example that i found
Thanks for your help
#include <IRremote.h>
int RECV_PIN = 11;
int result;
IRsend irsend;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned int  raw_muteTV[67] = {4700,4250, 800,1450, 750,1450, 750,1500, 750,400, 700,400, 700,400, 700,450, 650,450, 700,1500, 700,1500, 700,1550, 700,400, 700,450, 650,450, 700,400, 700,450, 650,1550, 650,1550, 700,1550, 650,1550, 700,450, 650,450, 650,450, 650,450, 650,500, 650,450, 650,450, 650,450, 650,1600, 650,1550, 650,1600, 650,1550, 650};
unsigned int  raw_muteSB[77] = {4700,4200, 700,300, 700,300, 700,300, 700,300, 650,1300, 700,1250, 650,350, 650,350, 650,1300, 650,1300, 650,1300, 650,1300, 650,350, 650,350, 650,350, 650,300, 650,4350, 600,350, 650,350, 650,350, 650,350, 600,1350, 650,350, 600,400, 600,350, 650,1300, 650,1350, 600,1350, 600,400, 600,350, 650,1300, 650,1350, 600,1350, 600,350, 650,350, 650,350, 650,1300, 650};
  irrecv.enableIRIn();{
void loop();
 if(irrecv.decode(&results) (
    Serial.print(results.); {
     irrecv.resume();
	switch(results.value){
    case 4700,4250, 800,1450, 750,1450, 750,1500, 750,400, 700,400, 700,400, 700,450, 650,450, 700,1500, 700,1500, 700,1550, 700,400, 700,450, 650,450, 700,400, 700,450, 650,1550, 650,1550, 700,1550, 650,1550, 700,450, 650,450, 650,450, 650,450, 650,500, 650,450, 650,450, 650,450, 650,1600, 650,1550, 650,1600, 650,1550, 650:
   irsend.sendRaw(raw_muteSB,77,38);
   delay(40);
The value after ‘case’ has to be a single integer. For unrecognized protocols you have to do something like hash the RAW values and use the hash to identify a button. Here is an article about how to do that:
