I have a arduino micro and I am making a project that requires a motor to only run when an Input is HIGH. The problem is the motor will just go on as soon as I connect it to the arduino even if the input is LOW and it just stays on until I disconnect it. Here is my code and maybe someone can help me out here.
int motorPin = 5;
int switchIn = 8;
int val = 0;
pinMode(motorPin, OUTPUT);
pinMode(switchIn, INPUT);
val = digitalRead(switchIn);
switch(val)
case HIGH:
digitalWrite(motorPin, HIGH);
case LOW:
digitalWrite(motorPin, LOW);
default:
How is your switch wired up?
Is one side connect to pin 8 and the other to GND or through a resistor to +5V.
If it connected to GND then you need to turn on internal pullup on pin 8 and reverse the switch logic (LOW = Pressed, HIGH = Released)
I don`t know how to reply to comments so I did this...
I have the switch wired from my batteries to pin 8.
A switch has two legs. Where does each one connect to? Is the battery ground connected to the Arduino ground? What else is connected to pin 8? Draw a picture!
Well i dont think im going to draw a picture but one side of the switch connects to the batteries and the other side connects to pin 8. And yes the arduino grounds to the batteries.
