Hello! Im making a project where if your weight shifts on a load cell scale, it makes the audio in my computer decrease.
So far, Ive built a working, reading scale with 4 load cells hooked up to my Arduino Rev3 Uno. Im trying to translate those readings through python to have a reading decrease the volume on my macbook. (At this point, I am at least trying to get any weight to decrease the volume, and then hoping I can work from there to alter it to any change in weight reading..)
Thing is, I cant get the readings to trigger a VolumeDown command through Arduino IDE. Heres my code so far:
#include "HX711.h"
#define calibration_factor -7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define LOADCELL_DOUT_PIN 3
#define LOADCELL_SCK_PIN 2
HX711 scale;
Serial.println("HX711 scale demo");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
float scaleValue = scale.get_units();
Serial.println("Readings:");
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
if (scale.get_units()>10.0);
{(Serial.println("VDown"));delay (500);}
My thought was -- at the end, if the reading is over 10 lbs, then it will send a VDown (volume down) signal. Through python, it will then trigger my computer to decrease volume. I feel okay with the python aspect -- but it's sending a VDown signal to python with every single reading (even of 0lbs)
Any ideas? Am I using the wrong if _ statement?
New to Arduino this week. Apologies to any lengthiness or lack of clarity. Appreciate any comments.
