I have been working on a project where I am getting a set of readings and dumping them into a csv file.I was thinking of adding an export to HTML option so that the user can can quick visual idea on what is going on while the device is deployed,in addition providing expandability in the future using XBEE or any type of Ethernet.
The first problem is that SD.open (file.extention, FILE_WRITE) does not support 4 letter extentions.So creating an .html file is not possible.I had to overcome this by using .HTM and hoping the browser would be smart enough to render it.
In order to give you an idea of how the page is supposed to be rendered this is the HTML code:
<!DOCTYPE html>
<html>
<head>
<title>Quantitative Metal Detector Data Visualisation</title>
<style type="text/css">
table { margin-left: auto; margin-right: auto;text-align: center; }
svg { display: block;margin-right:auto;margin-left:auto;margin-top:10px;margin-bottom:10px; }
body { background-color:#EEEEEE;}
</style>
</head>
<body>
<h1 align="center">Metal Detector Data</h1>
<table border="2" width="1000">
<tr>
<th>Measurement</th>
<th>Coil 1</th>
<th>Coil 2</th>
<th>Coil 3</th>
<th>Coil 4</th>
<th>Coil 5</th>
<th>Coil 6</th>
<th>Coil 7</th>
<th>Coil 8</th>
</tr>
<tr>
<td>1</td>
<td>100</td>
<td>200</td>
<td>100</td>
<td>200</td>
<td>100</td>
<td>200</td>
<td>100</td>
<td>200</td>
</tr>
</table>
<table border="1" width="100">
<tr>
<td><svg width="990" height="60" xmlns="http://www.w3.org/2000/svg" version="1.1">
<defs>
<line id="line1" x1="0" y2="50" y1="0" x2="0" />
<line id="line2" x1="0" y2="30" y1="0" x2="0"/>
<line id="line3" x1="0" y2="20" y1="0" x2="0"/>
<line id="line4" x1="0" y2="50" y1="0" x2="0"/>
<line id="line5" x1="0" y2="10" y1="0" x2="0"/>
<line id="line6" x1="0" y2="40" y1="0" x2="0"/>
<line id="line7" x1="0" y2="40" y1="0" x2="0"/>
<line id="line8" x1="0" y2="50" y1="0" x2="0"/>
</defs>
<use xlink:href="#line1" x="260" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line2" x="360" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line3" x="460" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line4" x="560" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line5" x="660" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line6" x="760" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line7" x="860" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<use xlink:href="#line8" x="960" y="00" stroke="black" stroke-width="2" stroke-dasharray="6 6"/>
<polygon points="260,60 260,50
360,30 460,20 560,50 660,10 760,40 860,40
960,50 960,60"
style="stroke:#660000; fill:#cc3333; stroke-width: 1;"/></td>
</svg></td>
<tr>
</table>
</body>
</HTML>
Using notepad++ and replacing " with " tabs with \t and newlines with \n I came up across this code on arduino based on the SD ReadWrite example I created this draft sketch:
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
updated 2 Dec 2010
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
File myFile;
int cx = 300;
int lineReadings[8];
int lineNo = 1;
int xcoord = 260;
void getReadings(){
for (int i=0;i<8;i++)
lineReadings[i] = random(0,10);
void printReadings()
Serial.print("Reading : \t");
Serial.print(i+1);
Serial.print(" = ");
Serial.print(lineReadings[i]);
Serial.println("");
getReadings();
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
Serial.println("Initializing SD card...");
Serial.println("Begin");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
else{
Serial.println("initialization done.");
renderHtml();
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
//Cannot open 4 characters extention name so html is replaced by htm
printReadings();
Serial.print("END");
while(1);
// nothing happens after setup
void renderHtml(){
myFile = SD.open("data.htm", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
//Begin with HTML file header
myFile.println("<!DOCTYPE html>\n<html>\n<head>\n<title>Quantitative Metal Detector Data Visualisation</title>\n");
//We cannot afford external CSS so we add them in the head section of the HTML and close the head
myFile.println("<style type=\"text/css\">\ntable { margin-left:auto; margin-right:auto;text-align:center; }\nsvg { display:block;margin-right:auto;margin-left:auto;margin-top:10px;margin-bottom:10px; }\nbody {background-color:#EEEEEE;}\n</style>\n</head>\n");
//Start printing the body and header
myFile.println("<body><h1 align=\"center\">Metal Detector Data</h1>");
//Create the Name Part of the Data Table
myFile.print("<table border=\"2\" width=\"1000\">\n\t<tr>\n\t\t<th>Measurement</th>\n\t\t<th>Coil 1</th>\n\t\t<th>Coil 2</th>\n\t\t<th>Coil 3</th>\n\t\t<th>Coil 4</th>");
myFile.print("\n\t\t<th>Coil 5</th>\n\t\t<th>Coil 6</th>\n\t\t<th>Coil 7</th>\n\t\t<th>Coil 8</th>\n\t</tr>\n");
//Create the Data part of the Table
myFile.print("\t<tr>\n\t\t<td>");
myFile.print(lineNo);//Print the Line Number
myFile.print("</td>\n");
//Go through each of the readings
for(int i =0;i<8;i++){
myFile.print("\t\t<td>");
myFile.print(lineReadings[i]);//Dump the readings into the HTML table
//Close the table
myFile.println("\t</tr>\n</table>\n");
//Start Printing the SVG part of the file
//Create the container table
myFile.println("<table border=\"1\" width=\"100\">\n\t<tr>");
//Create the svg header
myFile.println("<td><svg width=\"990\" height=\"60\" xmlns=\"http://www.w3.org/2000/svg\" version=\"1.1\">\n\t<defs>");
//Damp readings into the line euations
myFile.print("<line id=\"line");
myFile.print(i); //required to name lines differently
myFile.print("\" x1=\"0\" y2=\"");
myFile.print(lineReadings[i]); //Data input line
myFile.print("\" y1=\"0\" x2=\"0\" />\n");
//Close the definitions part of the svg
myFile.println("\t</defs>");
//dotPrint();
//Make the lines Dotted and place them in X coordinates
myFile.print("<use xlink:href=\"#line");
myFile.print(i);//syncronize with the line name afrom above
myFile.print("\" x=\"");
myFile.print(xcoord); //add the current point coordinate
myFile.print("\" y=\"00\" stroke=\"black\" stroke-width=\"2\" stroke-dasharray=\"6 6\"/>\n");
xcoord = xcoord + 100;
delayMicroseconds(100);
xcoord = 260; //Reset xcoord for next loop
//close the table and SVG
myFile.println("</svg></td>\n\t<tr>\n</table>");
//Close the html File
myFile.println("</body>\n</html>");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
The main problem occurs after the line //Start Printing the SVG
if the the code get un-commented.Even though if tested separately all the code functions create a working file i have to comment out part of it in order for the arduino not to get into bootloop crashing on the line
I do suspect it is a memory issue even though the Binary sketch size: 15316 bytes (of a 30720 byte maximum) seems to be ok.I also tried closing and opening the file halfway to clear the buffer but with no luck..
The board is a Duemilanove with 328P chip
Any help is greatly appreciated.
