Let me start with Coding is not my strong point..
I have a sketch for a 8x8 led matrix to display scrolling text. (I did not write it, just borrowed it
(Thank you Andrew who ever you are)
the letters displayed on the matrix are defined in the sketch (see below)
I can see font .h files added to other peoples sketches, I assume the whole alphabet + numbers
and symbols is defined in the file.
In this sketch the letters are a 5x7 font defined in decimal form
EX: #define R {127, 72, 76, 74, 49}
Is there a better way to do this?
Every time I change the sketch to display something new I have to add a new #define of the symbol,letter or whatever.
Can I make a Complete font file that can be called by importing a library within a sketch?
what is the best format for defining letters,numbers, and symbols?
I have seen the letter "A" defined different ways, hex, decimal, binary.....
how do you call the letters, to be used from a font file to the sketch?
Remember, coding is not my strong point
Thank Tim
* Show messages on an 8x8 led matrix (cathode rows),
* scrolling from right to left.
* Pinouts & code by Andrew
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 8, 9, 10, 11, 12, 13, 6, 7};
// (for some reason I ended up with different pinouts that Andrew's)
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
// Letter definitions based on 5 bit-wise columns (5 x 7 font)
#define SM {98,97,9,97,98}Â Â Â // Smiley
#define LE {0,251,251,0,0}Â Â Â //Thick Exclamation
#define SP {0, 0, 0, 0, 0}Â Â Â //Space
#define EX {0, 125, 0, 0, 0}Â Â // !
#define PE {1,0,0,0,0}Â Â Â Â Â //.
#define A {31, 36, 68, 36, 31}
#define B {127, 73, 73, 73, 54}
#define C {62, 65, 65, 65, 34}
#define D {127, 65, 65, 34, 28}
#define E {127, 73, 73, 65, 65}
#define F {127, 72, 72, 72, 64}
#define G {62, 65, 65, 69, 38}
#define H {127, 8, 8, 8, 127}
#define I {0, 65, 127, 65, 0}
#define J {2, 1, 1, 1, 126}
#define K {127, 8, 20, 34, 65}
#define L {127, 1, 1, 1, 1}
#define M {127, 32, 16, 32, 127}
#define N {127, 32, 16, 8, 127}
#define O {62, 65, 65, 65, 62}
#define P {127, 72, 72, 72, 48}
#define Q {62, 65, 69, 66, 61}
#define S {50, 73, 73, 73, 38}
#define T {64, 64, 127, 64, 64}
#define U {126, 1, 1, 1, 126}
#define V {124, 2, 1, 2, 124}
#define W {126, 1, 6, 1, 126}
#define X {99, 20, 8, 20, 99}
#define Y {96, 16, 15, 16, 96}
#define Z {67, 69, 73, 81, 97}
int dispSpeed = 10; // Constrols scroll speed (1 minimum, way too fast)
byte bit[8] = {128, 64, 32, 16, 8, 4, 2, 1}; // Used for bit comparisons
byte colVals[8] = {0, 0, 0, 0, 0, 0, 0, 0}; // Hold display columns (initaly blank)
// Define display string here
const int charNum = 25; Â Â // Number of letters in display string
//byte string[charNum][5] = {LE,SP,SP};
byte string[charNum][5] = {T,I,M,SP,I,S,SP,T,H,E,SP,G,R,E,A,T,E,S,T,LE,SP,SM,SP,SP};
//byte string[charNum][5] = {A,R,D,U,I,N,O,SP,R,O,C,K,S,EX,SP,SP};
 Serial.begin(9600);  // for troubleshooting
 for (int i = 1; i <= 16; i++) {  // sets the pins as output
  pinMode(pins[i], OUTPUT); }
 for (int col = 0; col < 8; col++) {  // set up cols and rows
  digitalWrite(cols[col], HIGH); }
 for (int row = 1; row < 8; row++) {
  digitalWrite(rows[row], HIGH);
 Serial.println(availableMemory());  // 670 bytes for charNum = 15
 for (int ltr = 0; ltr < charNum; ltr++){// For each letter in string array
  for (int y = 0; y < 6; y++){   // For each columin in letter + one space
shiftLeft(); // shifts display columns left
if (y < 5){
 colVals[7] = string[ltr][y]; }  // add new letter column on right
else {colVals[7] = 0; } // or empty space between
for (int x = 0; x < dispSpeed; x++){// loop to refresh display x times ton control scrolling
 display();
void shiftLeft(){
for (int x = 0; x < 7; x++){
 colVals[x] = colVals[x + 1];
void display() {
 for (int col = 0; col < 8; col++){
  for (int row = 0; row < 8; row++){
if (colVals[col] & bit[row]){
 digitalWrite(rows[row], HIGH);}
  digitalWrite(cols[col], LOW); // Turn on column
  delay(1); // Delay for POV
digitalWrite(rows[row], LOW);
  digitalWrite(cols[col], HIGH); // And off
// this function will return the number of bytes currently free in RAM
// written by David A. Mellis
// based on code by Rob Faludi http://www.faludi.com
int availableMemory() {
 int size = 1024;
 byte *buf;
 while ((buf = (byte *) malloc(--size)) == NULL);
 free(buf);
 return size;
