I'm in need of advice. I have a very simple project that counts bubbles through a tube. When there is not a bubble the photointerrupter reads HIGH. When a bubble passes, it reads LOW. I want to have a short delay as to not miss a bubble but I don' want it counting 1 bubble as 2 or more, which is what it does currently. Is there any way to make my loop pause until the gate goes HIGH again?
int Gate = 2;
int gateState = 0;
int led = 7;
unsigned long time;
pinMode(Gate, INPUT);
pinMode(led, OUTPUT);
gateState = digitalRead(Gate);
time = millis();
if (gateState == HIGH) {
digitalWrite(led, LOW);
digitalWrite(led, HIGH);
Serial.print(" TIME ");
Serial.print(time);
Serial.print(" Bubble! ");
delay(gateState = LOW); ???? Problem area.
delay(100);
Record the state of gateState into another variable "prevState" and see if the current state is different from prevState. Then once you see that it has changed, you then see if that current state is HIGH.
In your loop.
static byte prevState = 0; // you can make this static and have it inside the loop or global outside the loop.
gateState = digitalRead(2); // read the pin
if(gateState != prevState) // if the current state does not equal is last state (ie changed from HIGH to LOW or Vs., go in)
if(gateState == HIGH)
//increase counter
//else ignore it
prevState = gateState; // update prevState;
int Gate = 2;
int gateState = 0;
int led = 7;
unsigned long time;
static byte prevState = 1;
time = millis();
if (gateState != prevState) {
Serial.print(time);
delay(100);
This works much better than before. It won't do anything until the first bubble passes and then it prints the time from start and "Bubble!". The only problem is that it also prints "Bubble!" and the corresponding time to when the bubble passes; thus, giving two "bubble!" announcements/actual bubble. Is there a way to make it just read the one bubble? Going from HIGH to LOW, but now LOW to HIGH?
Well, I must admit that I'm not using the bubbles at this very moment. I'm simply placing a business card in the gate.
When I start the program and the gate is uninterrupted, nothing is printed. Once I place the business card in the gate, "Bubble!" and its time is printed. Then there is pause as long as the card remains in the gate. Once I remove the card, "Bubble!" is printed again with its time.
