I am using the adafruit example of the fingerprint sensor to print the hex value to the cloud.
As of now I am able to print that data on the serial monitor, but when I try to use the same logic or add that data to an array and then print that data to the cloud, it seems to be failing. Can someone please help me with this.
Here is the snippet of the code:
for (int i = 0; i < 512; ++i) {
//Serial.print("0x");
String a;
a= String(printHex(fingerTemplate[i], 2));
//char finger1[i];
StaticJsonDocument<200> doc;
doc["finerprnt"] = a;
//Serial.print(", ");
char jsonBuffer[512];
serializeJson(doc, jsonBuffer); // print to client
post_data(jsonBuffer);
Here is the complete code:
#include <ArduinoHttpClient.h>
#include <ArduinoJson.h>
#include <MKRNB.h>
//#include "VescUart.h"
#include <Adafruit_Fingerprint.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#define OLED_RESET 4
// Debug options
#define PRINT_AT true // Show or hide AT command output from the modem
#include <FlashStorage.h>
//D v28
FlashStorage(sum_one, int);
FlashStorage(addr_one, int);
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
int id = 1;
int var1 = 0;
int cursor = 80;
int getFingerprintIDez();
// PIN Number
const char PINNUMBER[] = "";
char apn[] = "soracom.io";
char user[] = "sora";
char pass[] = "sora";
// Server details
const char server[] = "unified.soracom.io";
const int port = 80;
NBClient client;
GPRS gprs;
NB nbAccess(PRINT_AT);
HttpClient http(client, server, port);
// connection state
bool connected = false;
// Publish interval
long previousMillis = 0;
long interval = 10000; // milliseconds // D v2orginial value: long interval = 20000; chnages the time interval in which it will report
//v4-from v33 of the arduino code
Adafruit_SSD1306 display(OLED_RESET);
#if defined(ARDUINO_FEATHER_ESP32) // Feather Huzzah32
#define TFT_CS 14
#define TFT_RST 15
#define TFT_DC 32
#elif defined(ESP8266)
#define TFT_CS 4
#define TFT_RST 16
#define TFT_DC 5
#else
// For the breakout board, you can use any 2 or 3 pins.
// These pins will also work for the 1.8" TFT shield.
#define TFT_CS 1 // D v25 changes to use pin 1 for CS in MKR1500
#define TFT_RST -1 // Or set to -1 and connect to Arduino RESET pin // D v25 changes to use built in reset pinout in MKR1500
#define TFT_DC 2 // D v25 changes to use pin 2 for CS in MKR1500
#endif
//D v15 for audrino to connect to fingerprint sensor
//D v2
SoftwareSerial mySerial(2, 4);
#else
#endif
const int DIN_PIN = 7;
int LedPin=6;
// OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
// to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
// SCLK = pin 13. This is the fastest mode of operation and is required if
// using the breakout board's microSD card.
// For 1.44" and 1.8" TFT with ST7735 use:
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST); // D v21 uncomment this and comment the line below to use 1.44inch display.Need to change the display font in case I use 1.44"
// For 1.14", 1.3", 1.54", and 2.0" TFT with ST7789:
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST); // D v22 uncommment to use this display
/** Initiate VescUart class */
//VescUart UART;
int rpm;
float voltage;
float current;
float power;
float amphour;
float tach;
float distance;
float velocity;
float watthour;
float batpercentage;
//Variable that will change the value
int lastAdcValue = 0;
int currentAdcValue = 0;
pinMode(SARA_RESETN, OUTPUT);
digitalWrite(SARA_RESETN, LOW);
pinMode(SARA_PWR_ON, OUTPUT);
//Initialize serial and wait for port to open:
start_and_connect_modem();
Serial1.begin(115200); // Serial1.begin(19200);
while (!Serial1) {;}
/** Define which ports to use as UART */
// UART.setSerialPort(&Serial1);
pinMode( DIN_PIN, INPUT_PULLUP );
// tft.initR(INITR_144GREENTAB); // Init ST7735R chip, green tab
// OR use this initializer (uncomment) if using a 1.3" or 1.54" 240x240 TFT:
tft.init(240, 240); // Init ST7789 240x240 // D v22 uncommment to use this display
// tft print function!
tftPrintTest();
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
Serial.println("Ready to enroll a fingerprint!");
//Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
id = sum();
if (id == 0) {// ID #0 not allowed, try again!
return;
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
//for (int finger = id; finger = id; finger++) {
int finger=id;
{downloadFingerprintTemplate(finger);}
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
return true;
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
while (! Serial.available());
num = Serial.parseInt();
return num;
uint8_t downloadFingerprintTemplate(uint16_t id)
// OK success!
Serial.print("Attempting to get #"); Serial.println(id);
int p = finger.getModel();
switch (p) {
Serial.print("Template "); Serial.print(id); Serial.println(" transferring:");
default:
Serial.print("Unknown error "); Serial.println(p);
return p;
// one data packet is 267 bytes. in one data packet, 11 bytes are 'usesless' :D
uint8_t bytesReceived[534]; // 2 data packets
memset(bytesReceived, 0xff, 534);
uint32_t starttime = millis();
int i = 0;
while (i < 534 && (millis() - starttime) < 20000) {
if (mySerial.available()) {
bytesReceived[i++] = mySerial.read();
Serial.print(i); Serial.println(" bytes read.");
Serial.println("Decoding packet...");
uint8_t fingerTemplate[512]; // the real template
memset(fingerTemplate, 0xff, 512);
// filtering only the data packets
int uindx = 9, index = 0;
while (index < 534) {
while (index < uindx) ++index;
uindx += 256;
while (index < uindx) {
fingerTemplate[index++] = bytesReceived[index];
uindx += 2;
uindx = index + 9;
String a;
//char finger1[i];
Serial.println("\ndone.");
//break;
void printHex(int num, int precision) {
char tmp[16];
char format[128];
sprintf(format, "%%.%dX", precision);
sprintf(tmp, format, num);
Serial.print(tmp);
delay(50);
// Make sure the device is still connected to CatM network
if (nbAccess.isAccessAlive()) {
// Enforce Interval
if (currentMillis - previousMillis > interval) {
//D v33
// Construct the JSON data to send
// doc["time"] = millis();
int currentAdcValue = analogRead(A0);
while(currentAdcValue != lastAdcValue)
lastAdcValue=currentAdcValue;
//Serial.print("last adc value: ");
// doc["Time"] = "July 21, 2021 11:38:00";
Serial.println("Modem disconnected, reconnecting");
connected = false;
connect_modem();
void post_data(String postData) {
//Serial.println("making POST request");
String contentType = "application/json";
http.post("/", contentType, postData);
// read the status code and body of the response
int statusCode = http.responseStatusCode();
String response = http.responseBody();
void start_and_connect_modem() {
// Send Poweron pulse
digitalWrite(SARA_PWR_ON, HIGH);
delay(150);
digitalWrite(SARA_PWR_ON, LOW);
// Turn on the modem
if (Serial) Serial.print(">>> Turning on modem...");
if (MODEM.begin()) {
if (Serial) Serial.println(" done!");
if (Serial) Serial.println(" error, could not turn on modem! Try power-cycling.");
return;
while (!MODEM.noop());
MODEM.sendf("ATI9");
MODEM.waitForResponse(2000);
// Run AT commands to reset the modem to global default settings
Serial.print(">>> Resetting modem to default settings...");
MODEM.sendf("AT+CFUN=0");
MODEM.waitForResponse(6000);
MODEM.sendf("AT+UMNOPROF=2");
MODEM.sendf("AT+CFUN=15");
MODEM.sendf("AT+UMNOPROF=0");
MODEM.sendf("AT+URAT=7");
//D v33
/*MODEM.sendf("AT+UBANDMASK?");
MODEM.waitForResponse(6000);*/
delay(2000);
// attempt to connect to GSM and GPRS:
Serial.print("Attempting to connect to GSM and GPRS");
//Serial.println();
connect_modem();
void connect_modem() {
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (!connected) {
if ((nbAccess.begin(PINNUMBER, apn, user, pass) == NB_READY) &&
(gprs.attachGPRS() == GPRS_READY)) {
connected = true;
Serial.println("Not connected");
Serial.println("You're connected to the network");
void tftPrintTest() {
tft.setTextWrap(true);
tft.fillScreen(ST77XX_BLACK);
tft.setCursor(0, 0);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(2);
int sum()
var1 = sum_one.read(); // D v19 read the value from addr 205 and see if it has any ID already stored in it
var1 = var1 + 1;
sum_one.write(var1); //D v19 store the ID value in the corresponding addr
return var1;
