the problem on my code is:
int button1 = D2; //button pin, connect to ground to move servo
and the error message is:
exit status 1
'D2' was not declared in this scope
help?
exit status 1
help?
D2 os not a number and or it is not defined
try:
// near the top of your code add:
#define D2 6 // Anytime D2 appears it will be replaced by the number 6 for Arduino Pin 6 in you case
//... other code
or
int button1 = 6; //button pin, connect to ground to move servo number 6 for arduino Pin 6 in you case
Z
