trying to put two scripts together what have I done wrong ?
so im trying to combine a hello world script with a script I found to run the HC-SR04 displaying the distance to nearest surface in cm
My issue is that at most ranges the lcd is giving numbers that dont really make any sense.
the lcd script
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, Rose !");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
the ranger finder
#define echoPin 2 // Echo Pin
#define trigPin 3 // Trigger Pin
#define LEDPin 13 // Onboard LED
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
 Serial.begin (9600);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
/* The following trigPin/echoPin cycle is used to determine the
 distance of the nearest object by bouncing soundwaves off of it. */
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 //Calculate the distance (in cm) based on the speed of sound.
 distance = duration/58.2;
 if (distance >= maximumRange || distance <= minimumRange){
 /* Send a negative number to computer and Turn LED ON
 to indicate "out of range" */
 Serial.println("-1");
 digitalWrite(LEDPin, HIGH);
 else {
 /* Send the distance to the computer using Serial protocol, and
 turn LED OFF to indicate successful reading. */
 Serial.println(distance);
 digitalWrite(LEDPin, LOW);
 //Delay 50ms before next reading.
 delay(200);
my script
  lcd.begin(16, 2);
  lcd.print("test of idea !");
 else {
 lcd.print(distance);
 delay(50);
What is wrong with the numbers that are printed ?
I note that if you print a 2 digit number after a 3 digit number then you are not clearing the last digit of the first number printed.
that sort of sounds like what could be the cause when I turned it on at ranges of about 9cm everything seams good but under that or much over that the numbers make litte sense what would I add to get it to clear the old number before a new one is put up ?
Either position the LCD cursor print some spaces then reset the cursor position and print your number, or always print some spaces after your number.
For bonus points, only print the number when it has changed.
For further bonus points, only print the number when it has changed by a significant amount.
