I have a piezo attached to my Uno and wired up such that when i tap it, analogRead() reads the values.
I have written this code (noob alert). I put some comments in.
When I run this the Serial Monitor runs 0 down the screen. When I tap the piezo a value or two appear (hard to tell)
My code seems logical to me… Just now sure why it keeps printing 0 to the monitor when the only Serial.println is in an IF statement that should only be hit when an index value is greater than 0 (ie: the array got values.
int aValues[20];
int i = 0;
int topValue;
int val = analogRead(A0);
// if a value, store it in the array
if (val != 0){
aValues[i] = val;
i++;
// if val is 0, there may or may not be values in the array
// as i got incrmented when a value was added, if it it greater than 0, there is
// an array to process.
if (val == 0){
if (i > 0){
topValue = TopValue();
Serial.println(topValue);
// set the array to 0
memset(aValues, 0, sizeof(aValues));
i = 0;
delay(2);
int TopValue(){
int top = aValues[0];
for (int z; z <= i; z++){
if (top < aValues[z]){
top = aValues[z];
return top;
What I think you mean is that it did not do what you want, but that is no surprise as you had not explained exactly what you wanted and I did say that I was taking the thread title literally
If you want to record the max value each time you tap the piezo then something needs to happen to set the max value back to zero between taps. That could be done by reading another input, by resetting the value after a period of time or perhaps by resetting it when the input has been significantly low for a number of reads
Paul_KD7HB:
Your piezo creates A/C. Do you have a circuit that takes care of the negative values?
Currents are tiny, and the ESD pin protection should be able to take care of negative pulses.
Unless you ‘tap’ with a hammer.
Must have that 1Megohm resistor across, to bleed any DC on the piezo to ground.
Try this (untested).
Leo…
const byte piezoPin = A0;
int threshold = 10;
int rawValue, piezoValue;
analogReference(INTERNAL); // remove this line if too sensitive
if (analogRead(piezoPin) > threshold) { // only process/print when tapped
int piezoValue = 0; // reset
for (int i = 0; i < 1000; i++) { // multiple A/D readings
rawValue = analogRead(piezoPin);
if (rawValue > piezoValue) piezoValue = rawValue; // store peaks
Serial.print("Peak value: ");
Serial.println(piezoValue);
Wawa:
Unless you 'tap' with a hammer.
Leo..
Your code works a treat. Thanks so much Leo..
Apologies to all for not being more clear in my title. Will do better next time.
